[Z06] Do CCW 505a 19x13 rear rims rub with mich zero pressure 345's
I just bought a set of ccw 505 rims they are 18x10 up front and 19x13 rears. I am putting 275s up front and 345s on the rears these are mich zero pressure run flats. My question is will I have any rubbing issues at all on my 2007 z06 ? Anyone running this set up? Thanks for all the help.
If you are using the right sized 275's and 345's for tires you should.be fine. I.highly doubt that CCW built a.rim cor.the C6Z that doesnt work w properly sized tires.
