[Z06] What size torx bit of MAF sensor?
Thought I'd clean my MAF sensor the other day, and in trying to remove it from the housing, I found that the torx bit set I have does not have one to fit. Mine are either too small or too big, but since they are not stamped with the size, I don't know what size to go buy.
Anybody know for sure what size to use?
Thanks in advance for your trouble,
CL
CL
A T20 fits my 09Z MAF (July 08 build).
CL
CL
You can purchase the appropriate TORX bit from Halltech, while other's have found specialty stores to order it from.
http://www.halltechsystems.com/WIHA_...s_p/171654.htm
Depending on model year, your MAF may be held in place with a tamper resistent TORX Plus T-20 screw...
Use a dremel to remove the pin in the center. Then use a regular torx bit to remove the bolt.
