[ZR1] Paint, or not to paint, that is the question?
Crap! I noticed the same thing when I did my first wash on my Carbon Z06 which has almost the same hood. Just like you I heard a weird popping sound when washing/rubbing the sponge over the front driver side of the hood and was not really sure what it was. Never went away and now seems to happen (when I wash or wipe it down with quick detail/microfiber towel) on most of the front side of the hood. Now I guess I know what it is lol! I'll have to hit up the dealership and see what they say. My car is IO, hopefully it will not require a fender repaint too! Just put a clear bra over the entire hood and fenders a month ago also. If they have to replace the hood under warranty I wonder if they will replace that or if I'm just SOL?
Just curious.Does anyone NOT have that popping sound when wiping the hood down with a rag?I just assumed this is normal/acceptable.
I have the popping sound since new. I'll let you know if the hood flies off the car.
Received 1,460 Likes
C1 of Year Finalist (stock) 2019
2018 C1 of Year Finalist
Replace the hood
Keep all paperwork
Demand the hood be painted off the car
Talk with the body shop
The color can be tinted to match vs blending into the fenders (worst thing they can do - ruin the OE finish)
I assume the shop will be shooting waterborne
Tinting and color match is better with water vs solvent.
Keep all paperwork
You may be in luck, if you want to call it that. Blade silver is one of the most difficult paints to color match - that's the bad news. The good news is that most of the hoods don't match from the factory.
And the hood doesn't appear to be the only victim. Take a close look at all the body parts for color matching, especially on an overcast day.
So, it's likely that your newly painted hood could be just as bad as it was when it came from the factory, or it could match more closely.
Good luck.......
Good luck.......
That just seems silly to me. Stuff happens and just because it's a $100k doesn't mean a few won't have a silly defect like the OP's.
I wouldn't think twice about having the dealer replace the hood and repaint, especially a car that new. I mean, are you really considering leaving it be and/or opting to squeeze some super glue in there and hope it works?
It not only occurs while wiping the hood but also on the fenders and front bumper,I just thought it was normal .Now you have me worried,what should I be looking for? Emmett
This may not be possible, but on a 120k car I would think GM would make an exception -- all the parts of the car are painted off the car at the factory. Couldn't they just get you a factory painted hood? Considering they only make a few of these cars a year, and they come from bowling green, I'd go so far as to show up at BG and ask.
Are you listening GM?
#33
Not to add insult to injury here, but metallic silvers are the toughest colors to match. If it were me, I would tell the dealer to go ahead and paint the hood only and then examine it carefully with different lighting conditions, to make certain I am 100% satisfied.
#34
_"SCOTT"_
If the dealer is going to paint it, they will have to mask the window. If this were the preferred way to manufacture the hood then the vendor would do it that way but they don't. There's a crevice that surrounds the hood window accessible from the top, that would make the paint process much more difficult do do the job right and keep over spray out.
When you look at the hood from the back, you really don't want to see excess paint that filtered down into this cavity.
I would make a real strong effort to get one shipped to the dealer already painted, just like they're delivered to BG. I'd really like to hear GM's argument as to why this can't be done???...
There's no reason that I can think of except cost, and that's certainly not a good enough reason "for me" after I spent $100K +-
#35
Tim, I wish I could, but you can't see anything just hear it. If you put light pressure on the hood as when you are cleaning with a cloth, you can hear a "popping" noise as the 2 sections of the hood stick together again and release. It was only on one side and 4" to 5" long at first, but now both sides of the hood and 12" to 14" long now.
#36
What is wrong with the new hood(s) that they have to go back?
#37
The first hood recieved by the dealer was worse than the one I currently have. The craftmanship of the CF was poor at best. The dealer even made the remark that it look used. If this carbon fiber was exposed like the roof I would not have purchased the car. I'll take some pics and post when I have time.
FYI if you do get your hood replaced it doesn't come with the window installed. You have to request a new Window also.
#38
The popping sound on the hood is NOT a structural defect (it is not delamination).
GM using MORE glue would only unleash a RASH of bigger problems.
The underside of the hood was never intended to be a class A surface. That is why it is not coated with anything.
#39
The finish on the CF on the underside of the hood is the same as that of the roof - perfect in every way.
As for the bonding, it appears the two pieces are glued and that the gluing process has failed on some of the hoods. No popping or creaking here.
#40
Ditto on my 2010
Not sure where the above came from, but I was more than curious about my own 09 ZR1. Just went out to the garage to inspect the finish and method of attachment between the two panels.
