[Z06] Adding NAV to a 2LZ Z06 without NAV
Just got my Z this week, and to my dismay it didnt have NAV but it was the 2LZ LMB so it wasnt that big a deal.
1) How hard is it to find a unit (the other cars i looked at the Z06 comes up when you turn it on.) I assume it will have to be out of a wrecked one.
2) How hard is it to do? I assume it plugs into the stock harness
3) What else is required? Bezel, is there upgraded stero for this?
4) Approx cost for a unit. If its 1500 then its not even worth trying. for 500 or so its worth contemplating.
5) Has anyone here done it and documented steps required?
6)Is it year specific? So do I need to look for a 07, or will 06-11 work?
Thanks again!
Thanks again!
my guess is responses will come in as 'don't bother, factory nav sucks'. I have the same setup on my 08, thinking of going Kenwood. You can do a whole kenwood setup with harness, adaptor for steering controls etc for less than $1100 (6980 model)
Location: Canonsburg home of Yenko Chevy (gone but not forgotten) Western PA
Thanks again!
Thanks again!
I did this also on an 06 2lz. Easy to do just plug and play. You need a GPS antenna. Do a search and print out the directions for install.
The only thing that did not work was the Speed Volume control and the voice command (which work together). I'm going to take it apart and see if I can find the plug in that I missed.
If you want to sell your old unit please let me know , I'm in NL Canada
Thanks again!
Thanks again!
Here is how you install it
http://www.skyhighphotos.net/CorvetteNAV.htm
Good luck
Thanks again!
Thanks again!
I would go aftermarket for sure, I've had 2 stock units and now a pioneer. My pioneer is 4 years old and blows the current GM unit away to this day. I have a '08 z06 2lz and steering wheel buttons are still used with after market unit. Only draw back being HUD integration but not a big deal for all the other added goodies gained.
I'd rather stick with a stock headunit if i were you, because i had 3 differents kenwood really high quality unit in my supra . Dnx 9140, dnx9280 and dnx 9960 those were the top of the line and every single one of them and issues. Like bogs freeze need frequent updates. I know garmin navi is 3 times better than gm but with stock navi from gm you have the peace of mind plus those are really hard to dialed in for the sound setup its a real pita.
my 0.02
my 0.02
Received 3,841 Likes
"Ask Tadge" Producer
The 9960 gets annoying if you enable the traffic updates; doing so automatically kicks in the context-sensitive advertisements (they gotta pay for that traffic data somehow). Since I don't care about traffic updates, and really, really hate the ads, I just disabled that part.
As far as the OP is concerned, I wouldn't spend $1 on the factory navigation system, let alone a few hundred dollars. Just get a standard double-din aftermarket and call it a day. You'll get a substantially better entertainment system and a better navigation system.
jas
IF someone wanted to go oem, will a newer one fit an older car, i.e., 2010/11 Nav into an '08 ?? Anyone know?
Thanks for info ,I didn't know that . I know the 06 and 07 are the same ,Some have posted here that a 10 or 11 will fit an 07 . I haven't tried that conversion and to spent 500, or so is a hard way to find out if it will work , So I have someone that has tried it will chime in .
I hope someone knows 100%, there are a few listed online (newer ones)
Here is what I was looking for,
FYI, my buddies 2010 Nav unit fits (and works) in my 2007 c6z. This also requires you to have the bose system.
You will also need to have the unit unlocked with a tech II programmer from the dealer.
posted by AtomicBob on 08/23 /2010
here is thread
http://forums.corvetteforum.com/c6-p...ipped-obo.html
Hope This Helps
here is thread
Hope This Helps
great. Just need to decide if worth it, seems those for sale (newer ones) want alot of $$ ( $1000- $1200) , that plus maybe the cost of the CD's, plus the dealer cost.....is it worth it or just go Kenwood. Thinking..........
