[Z06] Question about ticking noise
Well, I just bought my 07 Z06 with 18,500 miles on it and it was seemingly perfect until I started hearing a faint tick in the engine during acceleration. Took it to a performance shop and the owner opened up the valve cover only to discover that the pedestal is worn, which is causing the exhaust rocker to twist on the valve and make the ticking noise. Apparently the previous owner took all of his performance parts out and restored it to stock, but didn't torque things down correctly. Here's to hoping they fix it and cover it under the powertrain warranty. Anyone have any experiences like this? Any advice? Thanks in advance.
The Consigliere
Received 5,476 Likes
Actually this is good news. You found an issue before it could hurt anything.
Far, far better than the alternative. Just make sure it's put back together correctly, and you'll be fine.
Oh, and go buy a lottery ticket tonight. Luck is with you.
How do you know for sure if the prior owner had performance parts in there. It could be the roller bearings from the rocker arm that have begun to fall out. That would make the rocker arm off axis too.
If this is the case I would replace ALL of the rockers preferably with Harland Sharp modded ones...
Thanks guys. We checked the roller bearings and they were good to go. Tooling marks were all over the bolts and there was no repair history on the car when I purchased it. I just hope they fix the problem correctly and thoroughly and cover the charges. I've only had it for two weeks and miss it terribly already. Hope it doesn't take too long.
Your factory warranties (including the Powertrain) cannot be extended. However, if you choose to go with an extended warranty from GMPP, depending on which plan you choose, various components of the engine and transmission are covered. GMPP’s website can tell you what each of the plans covers or you can talk to Dennis Fichtner about this. He’s very helpful to the forum regarding GMPP plans and pricing.
Thanks,
Laura
GM Customer Service
Thanks,
Laura
GM Customer Service
Yeah I hear ya, but the svc mgr assured me that the previous owner's negligence shouldn't affect whether they cover it or not. They just sold me the car two weeks ago, so I believe either GM will cover it or the dealership will. Either way, I don't believe that I should have to pay a dime. I'm keeping my fingers crossed. I love this car and this really doesn't sit well with me.
Is the ticking not normal? Mine ticks on acceleration and so does everyone else I know that has one. I have heard the tick in 4 different Z06s. Call me crazy. Or maybe ALL of our cars are messed up? I did wonder what it was but after hearing it in other guys cars I figured it was normal. My car was stock when I bought it. I have since added many mods pushing 660 HP and have not had a problem. But it still ticks...
St. Jude Donor '12
Talk to Dennis Fitchner (sp?) about the GMPP warranty....you definitely want to get one in this case.
He is also here on this forum. He will get you the best bottom line price for the GMPP warranty. Most all the guys here who get the warranty go to him.
Enjoy your new 'Z!!!
Tim
Tim
