[Z06] Anyone do a mild cam without headers?
I'm thinking about doing a mild cam in my '07Z. Something like the LG Executive or the G7X1 cam for a little extra midrange torque for the track. The car is a daily driver so I don't want to compromise driveability and I don't want to change the exhaust loudness. I understand the Executive cam is so small that I can use the stock springs with it. To me that's a bonus as I've heard stories about failures with some of the aftermarket dual springs. I want to be able to install it and forget it. I don't want to have to replace springs and pushrods every year or two.
I realize that headers are a must with the more aggressive cams, but with the smaller ones such as this, will there be a big tradeoff?
Thanks in advance.
Jonathan
Thanks in advance.
Jonathan
I am currently researching the same thing. Another option to look at are the Street Bully by Quality Motorsports (Vette-air.com) and the Stalker by Ragin Racin (raginracin.com). I have bought from Shawn at Ragin Racin and have had no complaints. He is very helpful. Have PM'd with Carlos from Vette Air and he is quick to answer my questions.
Almost any cam you decide on will run fine with the Z06 OEM exhaust. However, headers will add torque across the entire RPM band.
You should also consider the Katech Torquer cam.
Just had the Street Bully Cam installed in mine. Haven't had time to dyno the car after the install, but just came back from Watkins Glen where I got to run it pretty hard for at least one session before the rain hit. Car runs and sounds great with the stock exhaust.
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,426 Likes
St. Jude Donor '08
I ran cam only (no cold air, headers, heads) for a year on our Z06. It made 518 rwhp with no other mods besides the cam and springs. It added power, but felt lazy down low. With the addition of headers and cold air, it made 555/510 rw. That engine is long gone now and we are currently sporting a Katech 427 (582/555 rw) with their torquer cam. I could not be happier with the results. The cam is a beast down low, but I still get 25+MPG with it. I would not recommend any other cam over the torquer unless you are an all out drag racer.
Was that with the LS7 clutch? If so, how did the car hold up to the 518hp? I may need a new clutch soon and NEVER plan to add headers, but I may do a cam and expect around the same power (which is fine to me). The ZR1 clutch is $1500 in just parts and the Z06 clutch is like $350. If the LS7 clutch could hold 520ish, I would rather just stay with it vs. blowing big dollars on a clutch that holds power I NEVER intend to have. Also my car will never see hard launches at a drag strip, but it will see track days, which I think is less of an issue with slippage as I will never drop it off the line.
What was the torque figure for the car before the headers (when it dyno'd at 518 rwhp)? I'd like to know how much of a torque gain you experienced with the headers and CAI.
Supporting Vendor
St. Jude Donor '08
Even for raod courses, I do not like the stock clutch. I had it stick to the floor a few times coming down the front straight at thunderhill. I would not recommend anything other then the LS9r for cars that are 550rwhp of less and want a stock pedal and stock manners. We've installed them on plenty of stock cars and they are fantastic. many of the local road racers also have that clutch and are amazed how well it performs. I understand where you're coming from on not wanting to spend the money, but I would not want to ever have to change the clutch again. A stock clutch assembly will still run you about $450 with a flywheel so the cost diff is about $1k.
If you decide that you want a clutch, I will hook you up.
We did the cold air first and it rose to 535/478.
Then we added the long tubes and it rose again to 554/510
Here is a graph representing just the addition of long tubes and a re-tune. There are points in the curve that it picked up ~45 lbft and it picked up 19 rwhp and 33 rwtq peak with an average gain of ~20rwhp across the board.
bolt ons only
I did the Katech air cleaner, LG headers,High flow cats and X-pipe and tune. I put 345/30/19s for grip and don't need any more. 510hp rw is all i need for the street and an occasional track run.
With the cam only numbers is 518/460
Supporting Vendor
St. Jude Donor '08
Keep in mind that was with a .238/.248 .610/.620 112 cam in the car. You will never see those gains on a stock car.
I was referring to getting headers when I do a cam install. It seems the gains the headers make might be worth considering doing it-especially if as you reported the cam feels lazy down low--probably suffering some restriction and consequently lower torque.
On a stock vehicle, the consensus is that they don't do much.
Supporting Vendor
St. Jude Donor '08
Richie,
BTW, I'm sorry, but I'm lacking savvy when it comes to cam specs. How aggressive is the cam you quoted? How does it compare with say the Katech Torquer, or the the Ragin' Racin' Lethal. I quoted the LG Executive and the G7X1 but I don't know the specs on those.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Thanks in advance.
Jonathan
Thanks in advance.
Jonathan
Depends on what you want to do with the car. The Executive cam is a lot of fun low to mid range power. I've done a few cars with this cam, headers, and cold air and just make a stupid amount of torque...like 410-425 rwtq at 2000 rpm...which is a lot of fun.
The smaller cams do not do so much up in the higher RPM range so if you are going to spin the car a little higher up, maybe something like the X2 or X3 might be more up your alley.
Hit me or one of the guys up here at the shop and we will be more than happy to help figure a good combo out for you.
Anthony
Now if you say the cam caused the motor to make less hp than the OEM cam under 3k, but made more above 3k, I would not do the mod as that would not be fun or manageable.
Supporting Vendor
St. Jude Donor '08
Thanks for all your help.
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Hi
Give the guys at the shop a call and they can help you make your decision.
Remember, just putting a cam in requires much more technical expertise than an exhaust/headers. If the installer makes a small mistake on the exhaust install, all you have is a small leak. BUt if the installer makes a small mistake on the Cam install, you an have real problems.
We have some good dealers in Canada that can help with the install of our products.
And remember, we have a cam for every application and we developed them using all of our connections in the racing business and Comp cams.
I personally would not do just a cam. There are so many other ways to go to get good hp and drivability without ever putting in a cam.
On the other hand, you can put one of our mild cams in -With headers- and if you have npp exhaust, you will never know that you have anything done to the car.
At any rate, give us a call any time to discuss your project.
972-429-1963.
Lou Gigliotti
__________________
LG Pro LT Headers, MOST HP, MOST TORQUE
http://lgmotorsports.com/gallery/alb...no_compare.jpg
LGM http://www.LGMotorsports.com
Winner Daytona 250
22 WC Wins
"Most powerful Corvette headers on the planet"
Winner Daytona 250
22 WC Wins
