[Z06] Exhaust Flap Solenoid
Most likely the cheap solenoid failed. Its located on the rear passanger tail light area. Just remove both passenger tail lights for easy viewing. You'll need a 10mm socket to remove the stud holding it on the bumper. Just remove the electrical connect and the two vac hoses. Should only take about 10 minutes taking your time. The part costs about $50-60.00 online.
Most likely there is no problem with the vacuum lines, they're heavy plastic tubes.
I had my solenoid go bad, I don't have the P/N handy but it was $60.
There also is a control module next to the battery that controls (duh) the solenoid.
Some guys have changed out the solenoid through the tail lights, but its doing it blind. I'm like a bull in a china shop so I removed the rear valence to get to it.
To check if its the solenoid or the control module, disconnect the plug at the solenoid and start the car, check for votage at the solenoid, if you have power then its the solenoid.
Tim
Tim
Cruise-In VIII Veteran
St. Jude Donor '06
Actually it is a PIA. you need to remove the inner wheel wells, loosen the mufflers, then remove the lower valence and rear valence.
I am lucky that I have a lift, I wouldn't want to do it on the ground.
Now that I've done it before I might try it through the tail lights.
The solenoid is really slid onto a bracket that is bolted to the bumper support. I left the bracket in place.
I have the old part, I'll try to take pics to explain tonight.
If Slow Poke can do it in 10 min's I'd drive the car to him and have him change it.
The solenoid is not that difficult to replace. You just have to take out both right rear tail lights so you can see down in there hand have extra room to move around. I turned on a flash light and set it down in behind the valence so I could see a little better and the whole thing was no problem. I took my time and it probably took 25 minutes start to finish.
If anyone has any pictures it would be great.
I just went and took tail lights out to look. I guess I didn't put the clip back on that holds the little cover down.. What I remember is that, I put my fingers under the left side of the cover where it sits on the threaded stud that sticks up. Then I pulled straight up on it until it released. Try to slide the hard plastic hose to the front or disconnect the hose from the solenoid. You can give me a call if you want. I have mine opened up still so if need be I could go back through it with you. Nick
exhaust solenoid
I have the same problem. Just bought a Z06 with B&B bullets (too loud with cam and headers) and went back to factory exhaust (still has drone). Removing the solenoid was easy after removing the tail lights. There is a plastic cover that you have to pry off (it's easy if you use a trim removal tool that looks like a fork). With the engine on, I measured 14 volts on the connector and there was vacuum coming from the tank. Part number is 25794610, which PartsTaxi sells for $44.50. Currently, I have it bypass so the butterfly valves are always closed until the part arrives. I also installed and positioned a small hose clamp on the butterfly valve shaft so that it's not fully closed, like a quarter way open so you can still hear a little rumble when idle.
this is what it look like when you buy it from chevrolet, I believe it was around $40 << I could be wrong
1st step, while its running (and the exhaust is supposed to be closed) unplug 1 on the vac lines going to the actuator on the mufflers and put your thumb over the line and see if the other closes, if it does you have a torn diaphragm in that muffler. if nothing happens plug it back in and do the same with the other diaphragm. if nothing happens again then there is a problem. next go under the hood while the car is off and unplug the vac line next to the fuel line, if you hear a "psssshhh" then the lines are ok and its holding vacuum. then i would replace the solenoid that's behind the pass tail lights.
You guys do realize this thread is 4 years old....
It was a bit of a pain, but you have to try to twist the rubber connector and pull at the same time to break that seal. I actually had to use some pliers to twist the connector and ended up ripping it, but it came off! Got a new rubber connector at Autozone for a couple dollars. It wasn't an OEM replacement but it did fit. Be sure to remove both tail lights so you can use two hands.
Yes, thanks, amazing what the search function provides. Are you also one of those people that would have told me to use the search button had I started another thread?
Sorry for the sarcasm, I'll give you the benefit of the doubt you thought you were helping.
#33
Good to know I can get a replacement connector, if required.
#34
#35
You use the search button to try and find an answer to your question, and then if you don't find an answer to your question (and there isn't a recent thread about your question), according to forum rules, you are supposed to start a new thread. If you aren't aware of forum posting rules, then maybe you should review them.
#36
You obviously have nothing useful to add so go away. The photo was exactly what I needed to reference the hose location on the solenoid.
You must be proud of your contribution to the thread.
Have a great day.
Have a great day.
#37
dmuellenberg tried to help you out with a little forum guidance and you act like a class A D*ck.
Way to garner support. I'm sure all kinds of people will be willing to help now.
