[Z06] Stock Rods and Crank - How much power will they hold?
Through a rather unfortunate set of circumstances the motor is out of my car and being rebuilt. Its an 06 z06 with cam, ported heads, 102 intake, ported throttle body, and long tubes. I was definitely going to put a set of forged pistons in, but was wondering if I should put forged rods and a new forged crank in the car. The car made 590 wrhp and should make similar when put back together. How much power will the stock rods and crank reliably hold? I assume the rods are the weak link. Its a NA motor and with the compression it makes if I did a power adder later if would most likely be nitrous (don't see myself spraying more than 200 or so though). Would this be a time bomb waiting to go off or would it hold together? Thanks for the opinions.
FYI - the car will be mostly street driven (driven most days when the weather is nice) with an occasional trip to the drag strip or track day event.
Stock rods and crank should be fine for your application. I would not go with more than a 100 shot though.
Why would GM use titanium rods if they were weak. Titanium is hella expensive and seems to be a bit exotic than the old cast rods that used to be in my LS1 and LS2 engines.. What am I missing here?
Received 8,958 Likes
Titanium can be very strong but they can also be fragile. If they have been damaged you should inspect them closely. If you search on Titanium Rods you can find a Hot Rod Magazine article that discusses them and forged steel, and forged aluminum and the advantages and disadvantages of each.
Bill
Bill
Thanks for the input thus far.
FNQWK - did you stud your motor when you did the rebuild. That is the other thing I am debating. Also, what compression did you go with? I was planning on sticking with 11 to 1
So what are the advantages of sticking with the stock crank and rods? I have been looking around and it looks like I could sell my stock crank and rods and not be out that much money to have everything forged.
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,426 Likes
St. Jude Donor '08
Many people use the stock crank and rods for H/C engines. I know that Katech likes them and has yet to ever see a Ti rod failure. We debated using the stock stuff, but opted for a Dragon Slayer crank and Callies rods with Diamond pistons when Katech built our engine.
The quality of the billet/forging (process control and metal purity) is just as important as the type of material in a forged rod. The OEM titanium rods are Eagle forgings and they are definitely not top quality race parts like Oliver or Callies.
However, if they are in good condition, you can add bronze bushings to the wrist pin end and ARP bolts and they are a good rod for most applications.
If your budget allows, buy a set of billet steel Oliver rods with WSB bolts. They are the best available. The only problem is they are heavier than the OEM titanium rods and it will be very expensive to internally balance with a stock crank. Each slug of Mallory heavy metal will cost $100-200 and it will take several. It is almost better to buy a Callies crank and sell the OEM crank rather than spend a fortune on balancing.
So, if you decide to go with billet steel rods you should also replace the OEM crank with aftermarket.
Hope this helps your understanding.
Corvee - it was the number 3 cylinder I believe. And the piston was broke around the edge. It was missing material from about 9 o'clock to 11 o'clock position about the width of the ring.
Jim
All forged: JE pistons, Callies rods with stock crank - balanced. As mentioned in the other post, you are probably better off with an aftermarket crank (i.e. Callies with matching rods) by the time you pay to properly balance the stock crank. I also replaced the valves with solid stainless (intake and exhaust).
