C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Deka ETX30L battery question
Old 03-16-2011, 06:41 PM
spartanc6z06
spartanc6z06's Avatar
Default Deka ETX30L battery question
After my stock battery not holding a charge anymore and doing my research. I purchased a Deka ETX30L AGM battery the other day with the brass automotive posts. Z starts perfect with it and i saved 14.3lbs too!
After completing mission impossible and removing the Delco. I noticed the factory tie down is not doing its job holding the battery tightly in place due to the difference in size obviously.
My question is what everyone with the Deka, Braille and Odyssey batterys are doing to keep them from moving?
Old 03-17-2011, 02:46 AM
spartanc6z06
Anyone? puuuuurty please
Old 03-17-2011, 05:15 AM
Turbooo2u
Turbooo2u's Avatar
Where did you purchase this battery and was it expensive? It's what I'm looking for. Can you tell that the battery is moving around when you drive the car? I'm thinking you might try some thick foam insulation stuffed around the battery.
Old 03-17-2011, 08:16 PM
spartanc6z06
I purchased locally from battery world. With the brass posts it cost 250.00. Im thinking of doing something like that actually to keep it in place. I havent driven it, with how loose it is im too scared too.
Love this battery though, its pretty cold here still and after sitting for a few days it fires right up. Rated at 400 CCA but its under rated since the meter showed 600...
Old 03-17-2011, 10:33 PM
Turbooo2u
Turbooo2u's Avatar
I saw the ETX30l on the Deka website for $109. Is it the same battery you have? I think it's only rated at 350cca.
Old 03-18-2011, 04:21 AM
spartanc6z06
I noticed that on their website too but the sticker says 400 cca on my battery. Dont mind why i paid so much for it, i live in Canada. HOME of over inflated prices, if i was paying what yall pay for parts and install i would have the illest Vette in C-town...
Old 03-18-2011, 08:19 AM
08jetvette
08jetvette's Avatar
As mentioned earlier, that blue foam works good. I have the ETX18 and it starts my high compression motor with ease.
To Deka ETX30L battery question
Quick Reply: [Z06] Deka ETX30L battery question
