[Z06] Problems w/Check Engine Light & Traction Control System
Problem has been solved!!!!!
While driving yesterday; the check engine light started blinking and service traction system was displayed on the DIC. I did adjust my driving after these lights came on. After sitting overnight, same problems. Car info: 2009 Z06; M2W, Oil Remaining 47% and odometer reads 3000 miles.
Any suggestions other than maintenance service? Maybe 02 Sensor from bad gas? (prior to the trip, I did fill up w/gas)
Received 8,945 Likes
The reason the TC message shows up is there is a problem that is preventing the ECM from doing its part of the traction control function. Just a run of the mill emission system issue wouldn't do that. That probably means your problem is in the throttle control area. Some of those issues will also throw the car into limp home mode as well. You will need to get somebody to read the codes but a cheap scanner should be able to read the ones that concern you.
Bill
Bill
Check your batt & alternator. Those kinds of warnings are what the car will start throwing when the battery is low on charge. These cars are hard on batteries.
That will definitely cause a code to be set and the check engine light to light but it will not generate a Service TC message. There are only a certain number of OBDII codes that will also generate a Service TC message. He needs to focus on the failure not on non failures.
Bill
Bill
Bill
Bill
After a short drive tonight; I heard a clicking sound so I removed the plastic valve cover and noticed one spark plug cable OFF. Plug in the cable then went for a drive; now both (engine light & traction control) lights are off. And it's running & driving like a Z. Yesterday my co-polit said he heard a clicking sound but when I checked; it had stopped.
Thanks everyone for responding; this forum is awesome.
Bill
Bill, since you mentioned it; i believed a misfire did occur before those lights came on. Then we started reading the manual and forgotten about the misfire!
Drove 15 miles to work this am, everything ok, hop in at noon to go for lunch, running on 7cylinders, ticking on left side, "service traction control" message and CEL light on and all plug wires looked ok. Got on CF, did a search, found this thread, took cover off and found the problem: plug wire off coil pack! Problem solved, thanks to CF. 2010 Z 8800 miles.
Mrmaalox (09-10-2017)
C6/05 DIC problem
4th Gear
Fuel Gauge & Engine Maint light
Filled up with gas. Got in car and 'service fuel system' msg came on. Turned off engine, and checked filler cap was snug. Got home and
looked on the Vette forum and promptly purchased container of Chevron Techron additive.
Let set over night. Next day while driving to work the fuel gauge popped back and forth several times and end up on 'full' - where it should be. Engine service light is still lit. How do I reset this light?
Thanks a lot and thanks for all the previous info.
This happened to me today. Started my 08 and it was idling very rough and the exhaust smelled funny. Service traction control and CEL came on, so parked it. Went on here and found "check your spark plug cables". One was off the the coil pack. Started it up and ran much better and no smell from exhaust but CEL is still on. Does this take awhile to reset??
Thanks to the forum for good data base of info.
I really don't want this to happen again when I go to Vettes on the Rockies next month. Should I replace the plug wire that slipped off? How do you keep them from coming off?
