[Z06] Z06 OEM and Aftermarket Parts Weight List
#122
Is there a mistake here? The total wt given directly below is 74.5 lbs. When I did a Z06 header set up I weighed the total xpipe, headers and cats to be about 65 lbs which is consistent with the individual parts listed below?
I also weighed the ARH headers with hi flow cats and mid pipe to be 47 lbs and change if you want to add that to the list.
OEM Headers/Mid section/cats------> 74.5 lbs
OEM Mid section-------------> 19.4 lbs
OEM Manifolds---------------->25.80lbs
OEM Cats--------------------->20.40lbs
Total = 65.6 lbs
OEM Headers/Mid section/cats------>American Racing 1 7/8 w/cats(-18lbs)
Total = 65.6 lbs
#123
Brakes:
OEM Front Rotor----> 26.5 lbs (53 lbs pair)
OEM Front Rotor---->Mov'It Ceramic 11.9lbs (-14.6/-29.2lbs)
OEM Front Rotor---->Red Devil Titanium Ceramic coated 12lbs (-14.5lbs/-29lbs)
OEM Front Rotor---->LG Rotors (plain 2pc (15.7lbs)(-10.8lbs/-21.6lbs)
OEM Front Rotor---->OEM ZR1 (16.2lbs) (-10.3lbs/-20.6lbs)
OEM Front Rotor---->Coleman 2 pc. 16.25 lbs (-10.25 lbs/-20.5lbs pair)
OEM Front Rotor---->Perf. AFX(slotted)2pc 16.5 lbs (-10 lbs/-20lbs pr.)
OEM Front Rotor---->Racing Brake 2 pc slotted 17lbs (-9.5lbs/-19bls pr.)
OEM Front Rotor---->StopTech DRK(slotted)2pc 18.5 lbs(-9lb/-18lbs pr)
OEM Front Rotor---->Hardbar (plain) 18lbs (-8.5lbs/-17lbs pr.)
OEM Front Rotor---->DBA 5000 (slotted) 2pc (21lbs) (-5.5lbs/-11lbs pr)
OEM Front Rotor---->Eradispeed 2 pc slot/drilled ??
OEM Rear Rotor------> 19.9 lbs (39.8 lbs pair)**
OEM Rear Rotor------>Mov'It Ceramic 10.8lbs (-9.1/-18.2lbs)
OEM Rear Rotor------>Red Devil Titanium Ceramic coated 12lbs (-7/-14lbs)
OEM Rear Rotor------>Coleman 2 pc. 14.25 lbs (-4.95lbs/-9.9lbs pair)
OEM Rear Rotor------>Performance AFX (slotted) 2pc 14.25 lbs (-4.95lbs/-9.9lbs pair)
OEM Rear Rotor------>OEM ZR1 16.2lbs (-3.7/-7.4lbs)
OEM Rear Rotor------>StopTech DRK Rotors (slotted) 2pc
OEM Rear Rotor------>Racing Brake (slotted) 18.6 lbs (-1.3/-2.6)
Added: Mov'It Front & Rear Ceramic Rotors
Source: this link.
Pictures: #1, #2, #3, #4.
PS: looks as if the OEM Front Rotor weighs 25.9 lbs (vs. 26.5 lbs), and the OEM Rear Rotor weighs 20.1 lbs (vs. 19.9 lbs)? Could this be influenced by the different model years?
Source: this link.
#125
Please feel free to post the weights of parts you have weighed. See an incorrect weight let me know. Vendors could be a big help here. Post the weights. I'll update the list accordingly.
****To keep the list manageable parts to be included in the list must be able to be upgraded to something better or lighter****
****Conflicting Weights will not be changed until I get a 2nd verification from another member or a picture posted/PM'ed of the part weighed w/legit scale****
*Some parts are lighter, but keep in mind some parts are heavier due to better quality or more OEM functions retained
________________________________________ ________________________________________ ____________
CORVETTE MASTER PART WEIGHT LIST:
________________________________________ ________________________________________ _____________
Here is a head start in weight loss: The difference in weight between years
(Base Trims) **higher trim levels adds more weight
2006 Corvette Base Coupe 3179 lbs------------>2006 Z06 3130 -49lbs
2006 Z06 OEM.......... 3130 lbs -
2007 Z06 OEM.......... 3161 lbs +31lbs
2008 Z06 OEM.......... 3162 lbs +32lbs
2009 Z06 OEM.......... 3180 lbs +50lbs
2010 Z06 OEM.......... 3180 lbs +50lbs
2010 ZR1 OEM.......... 3350 lbs +220lbs
2011 Z06 OEM.......... 3175 lbs +45lbs
2011 Z06 OEM w/Z07. 3264 lbs +134 lbs
2011 ZR1 OEM.......... 3350 lbs +220lbs
Other:
________________________________________ ________________________________________ _________________
Suspension:7.5 lbs each front and 7.75 lbs each rear. GT2's are 7.70 lbs each front and 8.20 each rear.
OEM Shocks/Leaf Springs -------------> (35.5lbs)
OEM Shocks/Leaf Springs-------------->Pfadt Feather Weight Coil overs 6lbs per side 24lbs (-11.5lbs)
OEM Shocks/Leaf Springs-------------->LG G2 coil overs Fr: 7.5lbs each R: 7.75lbs each 30.5lbs (-4 lbs)
OEM Shocks/Leaf Springs-------------->LG GT2 coil overs Fr: 7.7lbs each R: 8.2 each 31.9lbs -3.6lbs
OEM Shocks/Leaf Springs--------------> Pfadt Coil Overs X 4 (32.5lbs) (-3lbs)
OEM Shocks/Leaf Springs-------------->Moton Coil Overs X 4 (36lbs) (+.5lbs)
OEM Front Sway Bar---------------->8.2lbs or 20.5 w/endlinks
OEM Front Sway Bar---------------->Pdadt Comp Sway Bar w/endlinks 21.9lbs (+1.4lbs)
OEM Rear Sway Bar----------------->11.8lbs
OEM Rear Sway Bar-----------------> Pfadt Rear Sway Bar ??
OEM Front/Rear Sway Bars-------->Pfadt Light Rate sway bars w/ links (18.8lbs) (-13.5lbs)
Other:
With the Moton coil overs (+ Eibach coil springs), the leaf springs are NOT retained. I do not know, however, how much extra weight is saved.
Anybody else who can jump into this?
Picture of my Z06:
#127
sub'd!
#129
Premium Supporting Vendor
#130
#132
#133
#135
Supporting Vendor
St. Jude Donor '09
Jason, I know you're waiting for the new Michelin Sport Cups with the new compound.
Do you know if those are available in 19" CTS-V rim sizes?
You might have a better power/weight than our car now. You need the ZR1 brake setup.
Looking good!
Looking good!
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
#136
Check with a tire supplier. I don't know if the sizes are available.
I'm actively looking for ZR1 brake parts.
#138
Need to update this with the new Katech carbon fiber deck lid. It would be great if this list could also be ranked in order of approximate $/pound reduction in each category. I'm sure the forum vendors could help with pricing.
#139
Stock decklid/glass------>Katech carbon fiber decklid with lexan rear window 20lbs (-33lbs savings)
#140
_Sloth Whisperer_
Just to kill some time, I went down the list after starting with the C6 Base Car weight of 3179lbs, and began shaving weight using averages from each category. For example, if the lightest tires listed saved 12lbs pounds from stock, I subtracted 6lbs. If the lightest clutch/fly combo saved 40lbs and the least only saved 10lbs, I subtracted 25lbs...and so forth. I figure this represents a good base for affordability, durability, etc when all things are considered for your dual purpose car that sees both track and street use.
Of note, I did not eliminate any safety features or creature comforts, such as airbags, interior panels, A/C, etc. The only exception would be the switch to sport seats (average savings) and Pfadt seat bases.
With all that done, considering lighter exhaust/wheels/tires/brakes/battery/coilovers/seats, and the like, with a carbon fiber hood/roof/halo/deck and lexan out back, I was able to pare the car down to a solid 2920lbs.
That's a +/- 260lb savings! Seems pretty good!
