[Z06] Just bought a Z06 and problems already :(
Hello,
Im new to the forum world. Last week I just purchased my first Corvette, Black 2006 Corvette Z06 w/5000 miles. 5 Days later the clutch pedal got stuck to the floor. I was driving the car aggressive prior to this happening. I had to have the car towed to the nearest Chevrolet dealership , they did examine it and said it needed a master and slave cylinder, so that has been replaced. I was just wondering if this is a common problem, or was i just not driving the car right.
Thanks alot, all responses appreciated.
Amit
Amit
St. Jude Donor '08-'09-'10-'11-'12
Since we do not know exactly how you were driving it, I cannot say whether you were driving it right or not. The car does not do well with a lot of clutch slippage. Replacing the master/slave is not what I would call a "common" problem (although it has happened). The cluth sticking to the floor does happen and the first treatment is usually replacing the clutch fluid. Also, once the clutch cools down this syptom tends to go away. Since you bought the car used it is very difficult to say whether you or the previous owner was the cause. Hopefully, all is corrected now.
St. Jude Donor '12
Hello,
Amit
Amit
Tim this was a different issue. This is problem that already occured with the master and slave cylinders, the other post was just asking about precaution to the rear end. Sorry for the confusion, i posted this before i received word from Ranger.
Amit
Amit
Hello,
Amit
Amit
My '06 had a few issues the 1st couple years.... they were all fixed under warranty and the car has been fine since.
Best of luck
Hello,
Amit
Amit
This has nothing to do with the clutch... this is a master cylinder issue that effects few Z06s. The clutch pedal was stuck to the floor with the car in gear and no slip.... different issue all together...
Happened to my 2008 with less than 10K miles on it and if anything I baby it.
I hate the stock clutch in these Z's... I change the fluid and it does stop for a while... I ordered a BC2 Carbon clutch...tired of this crap.. Love my Z hate my stock clutch...
It is actually quite common practice, replacing the master cylinders. It's the first step to you getting a "Well, we've done everything we can." while the car still exhibits the same problem.
My 08 was like this and now my 09 does EXACTLY the same thing.
Personally, after all the back and forth with multiple service departments and meetings with regional techs, etc..... the only real solution is a new clutch with a TICK master cylinder kit. If they're was an aftermarket slave and throw-out bearing, I would do those too but so far all we have to work with is GM parts. The stock hydraulic system is weak and a clutch that probably was designed (final production unit) for the wash-n-park guys then the those that actually drive these cars. Look how much TM there is in the factory tune. Great car, no doubt about that but it needs a bit of love.
key to keeping it from sticking is keeping the fluid clean... follow the ranger method... first time i bled it, it took forever cause it was so dirty... now its quick 1 or 2 cycles of it and it hasnt stuck since that day at the track and when i started bleeding it ... also watch ur launches...
IMO if u rev it up to 5k and drop the clutch.... the clutch is going to get so hot its gonna stick the pedal down to the floor .. pop it back up with ur foot.
to be honest... I dont Know... transmissions have always been my weak point ... never rebuilt one, never took one apart... so I hope someone else can chime in on this.. I would assume it has something to do with it being a hydraulic clutch
