[Z06] I am Lethal and will still be Lethal !!! (track results)
1/4 mile: 10.67 !! I am Lethal and will still be Lethal !!! (vid inside)
Hey Guys !
Went to the dragstrip yesterday...That was a great day ! 5 runs total and best run of 10.67 at 129mph with a 1.50 0-60' ! Still have room for improvement...
I'm having probs with my Torque Management , calling out all HP Tuner expert here, how can I remove the TM ?? I'm losing a few tenths here for sure...When shifting hard, the TM will shut the power down to 46% for 0.2 sec...Assuming that I have to shift 3 times...Maybe I can shave off 0.15-0.2 sec
http://www.youtube.com/watch?v=Vc2r5p0lem4
Thanks to Shawn of Ragin Racin
DOHC
DOHC
I don't know what's the track elevation. Is there a chart to calculate my hp vs timeslip ? I'd really like to know if my car isn't pulling as hard as it should be...
DOHC
DOHC
DA is calculated using the tracks elevation as part of the equation doesnt it? I believe the ET's are impressive nonetheless!!
Well that was a surprise... TRACK ELEVATION.... "0 Feet" above sea level per the track website. Thats nice!!! I didnt find the humidity and Barometer readings for that area yet. The DA in the video sounds about right.
What other modifications? 562rwhp seems pretty high for just a cam without head work.
Dohc is a friend of mine and I make the video, All the modifications are in the video. Nothing to hide, everthing is there...;-)
SLWSVT: for your information the elevation is 485 feets for the track at Pont-Rouge(Canada)
Thats weird.... about the sea level? Why does their website say 0ft?
yes is about the sea level...here is the website( it's only in french) http://www.dragpontrouge.com/?page=home
where did you see 0ft?
Here is a quote form the owner of the track taking from a drag forum in Canada ( it's in french again sorry)
La piste de pont rouge est à 485 pieds au dessus du niveau de la mer
