[Z06] Small Vararam Problem
Hi! I just installed a Vararam CAI on my 2006 Z06. For some reason the plastic rivet holding the lower portion of the intake to the front frame rail keeps popping out. Anyone else have this problem?
Supporting Vendor
Yes I had a similar problem. My right side fastener came loose. The hole is oval and too large for the fastener I had. I changed it using a drywall fastener with the butterfly hinges and a rubber washer. It holds fine now.
I had that exact problem. Ditched the plastic pieces and installed bolts with plastic grommets. Really solid now.
Mine fell off soon after installing the Vararam. Runs well without it. Hard for the intake to escape with the hood closed.
Okay, not a grommet. It got a new and improved fastener. I forgot I had a different shop secure it more firmly last time it was there.
Machine screw and nut combo (possibly a toggle bolt) with a couple of large flat washers. Excuse the nastiness. Haven't had a chance to detail it in awhile and got caught in the rain a few times.
