C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] does vented hood help reducing coolant temp.
Old 07-06-2010, 01:10 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by SLOWEST Z
will the radiator help in both stop/go traffic and highway driving?
if putting a large dardiator will drop the temp by 20 dgrees in stop/go traffic that is a great improvement.
In stop and go traffic, remember there is very little air flow going through it so you need to make sure the fan settings have been set to come on sooner. This combined with a larger unit will help.
If the car is completely stopped and no movement and the air the fan is bringing through it is 100+ degree's it is hard to get a big HP car to cool down. It would not be out of the question to see it run 220-230 in traffic on a hot summer day in Texas on some of the bigger HP cars. Once it was moving drop to 170-180.
Bad Dad (05-17-2016)
Old 07-06-2010, 02:13 PM
BADZ
BADZ's Avatar
Anthony,
What setting would you set a high hp SC car and at what %? I have the upgraded rad.
I was in mine on Sun. and it's was like mid 90's in Houston and my temps were hanging around 210-220 but never once did I loose AC.
Vented hood soon to come (hi-tech hood)
Old 07-06-2010, 05:14 PM
C2C6Z06
C2C6Z06's Avatar
St. Jude Donor '08-'09-'11-'12
This is exactly what my 08Z will do...Tuned for fans coming on sooner and a 160 T-stat. Still, the A/C will cut out when the coolant hits 230 in standing (or near standing) traffic. Once moving, even at 20mph, the temps drop quickly...F'N LA traffic
Old 07-06-2010, 05:47 PM
NORTY
NORTY's Avatar
Randy, I have a 160 degree T-stat.
You mean to tell us that a 160 T-stat is no more effective than the stock 186 T-stat is when temps are 200F? Uh-oh, you've discovered the big lie...
Old 07-06-2010, 07:11 PM
LEAVINU
LEAVINU's Avatar
Honestly, I dont mind 220 coolant temps in 100deg weather with a H/C car; its just reality.
What I'd like to know is how in the world can I keep my A/C from turning off? Sweating my a$$ off in traffic in 100deg weather is no fun.
Please someone tell me the answer to the a/c shutoff challenges many seem to be facing.
Old 07-06-2010, 09:17 PM
j4three
j4three's Avatar
St. Jude Donor '08
See this recent thread in the FI section for an explanation and solution
http://forums.corvetteforum.com/c6-f...blows-hot.html
Old 05-14-2016, 08:58 AM
Whis9
Whis9's Avatar
I know, I know old thread
What are you guys running coolant wise?
Antifreeze, water with additive , antifreeze with additive?
Old 05-14-2016, 09:08 PM
Unreal
Unreal's Avatar
Received 2,314 Likes on 1,793 Posts
First step is to make sure it isn't overfilled. If there is too much ac coolant in it, the pressure switch that shuts it off trips very easy. A lot of factory cars were overfilled. very common on vettes.
After that, upgrading radiator/fan typically solves that.
Old 05-15-2016, 01:28 PM
carpe dm
carpe dm's Avatar
i don't know how good using waterwetter is. if you have experience with water wetter please let us know.
I think it is effective in cars that run straight water, rather than a coolant mix. With a normal coolant mix, I find NO temp reduction.
Old 05-17-2016, 12:36 PM
olddragger
olddragger's Avatar
if you are running straight water then you sure don't want coolant temps of 230!
For those that change the percentages of the normal coolant and run ---for example--a 70/30 mix. Keep in mind that you have changed the coolants ability to avoid nucleate boiling.
Adequate cooling of the metals surface can get a little technical and unless you know what you are doing--IMHO run the regular coolant.
Old 05-21-2019, 05:36 PM
James Hauser
1st Gear
James Hauser's Avatar
I have a 2008 with headers and also a electric water pump in stop and go traffic my tempe will get up to 220 but very rare that they do if car is completely stopped the tempe will never get above 194. when I had the old water pump when car was stopped the temp would get as high as 230 sometimes and while moving with old pump it stayed around 220 with the electrical it stays between 180 and 190. I am still looking for more ways to get heat out of the engine bay area and have been thinking about the hood also.
Old 05-21-2019, 06:01 PM
KurtsZ06
KurtsZ06's Avatar
Water wetter is very effective, I use it in my big block C2 along with my Z06. It stabilized temps in my Z to 190, irregardless of ambient temps. In my C2, sitting in traffic was a sure fire recipe for the expansion tank to start releasing coolant. With no other changes, it now holds coolant without any purges.
water wetter is a cheap way to address overtemps. Try it first, long before you spend over a thousand for hoods, fans, etc.
Old 05-22-2019, 10:54 PM
  #33
rabrooks
rabrooks's Avatar
I added the 2014 camaro hood vent to my 09 z. and it helped. Looked good too. I had headers and I pulled them and wrapped them with exhaust wrap. Overall change was very positive.
Quick Reply: [Z06] does vented hood help reducing coolant temp.
