[Z06] Kooks header install help
Cruise-In II Veteran
Cruise-In III Veteran
I am doing the Kooks longtube install on my 07 Z06. The left side went right up, right side not so easy. Do the sump lines need to be disconnected from the oil pan? How about the starter? Motor mount pulled on right side?
i installed a lg super pro long tube headers few weeks ago, and yes you need to remove the oil lines to install the passenger side and i did remove the wire that was connected to starter to make a easy intall. i didn't touch the motor mount.
make sure you disconnect the battery before the install
good luck,
james,
good luck,
james,
I just installed kooks on my 07.the oil lines need to be take off. I didnt remove any wires or mess with motor mount.
Looking for seals for oil lines now and no one in NC has them in stock.
