[Z06] Buying a C6 Z06, what to look for??
I have a C5 Z06, and a friend of mine is looking for a stock C6 Z. Being that I am not as familiar with the C6 Z, what types of things should we be looking at aside from the normal wear and tear? What can go wrong or begin to fail on the C6 Z with low mileage? Thanks!
Cruising
I'm sure plenty of other people will have more suggestions, but I'd look at the clutch fluid to see if it's dirty or not. Apparently there is an issue with clutch dust dirtying up the fluid easily.
I'd check for abnormal tire wear, strange noises, clutch slip, etc. 500 miles can be a lot if they were driven a quarter-mile at a time.
Other than that, mechanically it functions the same as your C5, minus the dry-sump.
Pop the hood, kick the tires, I usually jump in and honk the horn and turn the steering wheel. hehehehehehe
Other than that make sure it hasn't been tuned.
Tunes void the warranty if something goes pop under the hood.
James
Cruising
The only other thing I've seen come up a lot recently has been problems with the exhaust valve guides and/or the guides themselves. Some people are having valves drop into the chamber (seemingly at random since it happens at varying mileage to both modded and non-modded Zs, not sure what you could do to check for guide wear that won't involve pulling the heads.. just food for thought I suppose.. Good luck in your search!
