[Z06] Oil level in tank
Oil level in tank
Today was the first time I started my car in 4 months I checked the oil and it was 14 inches below the top of the tank. It was full (middle mark) when I parked it. I guess it really leaks back into the engine after time. It started right up and the oil level was the same as I parked it when a checked it.
Now the question is this normal? If someone parked this car with out checking the oil and then checked the oil before starting it what would you do when it is this low. This is 5 inches below the bottom of the stick.
The Z06 is different than most cars. The oil does drain from the tank back into the engine and we Z06 owners need to measure the amount of oil in the tank rather than the engine. GM recommends you check oil level after engine is up to temp and then shut off for a given period of time (longer than 5 minutes, but less than 20 minutes). If you wait too long, you may get a false (too low) reading. See your owner's manual.
