[Z06] Tire life?
Cruising
Tire life?
I have an 09 Z06, I don't drive the car hard, haven't tracked it yet. I'm getting things ready to track it next month for the first time. it only has 6,000 miles on it. I took the back wheels off yesterday, checking brakes and tire tread. the tread on the inside of the rear tires is down to the wear marks, the out side is better has probably about an 1/8 of an inch above the wear marks. Front tire are in great shape almost new looking. Is this normal for a z06 to go threw a set of rear tires in 6,000 miles? I know if I'm doing burn outs, or drag racing, or other track events I wouldn't be surprised at them being this low, but I've babied this car so far.
My 07 just turned 11,400 miles and I'm down to the tread wear bars. I have a set of new GY F1's sitting in my garage. I'll be attending a HSDE at Road America in April and when I get back I'll have about 13,700 miles and I'll change the tires then.
I have even wear so even under the best of circumstances I figure the OEM tires are good for no more than 15K miles. Track it or have alignment issues and all bets are off.
Hope this helps
Tom
Hope this helps
Tom
Depends on how you drive.
3 minutes and no miles if you drive like this.
http://www.youtube.com/watch?v=4v0P2LHSBvo
The Consigliere
Received 5,450 Likes
Ken,
I seem to only get 7 - 10k miles out of mine. Also noticed the first 5k miles or so the stock GY's are pretty decent on performance, the next 5k miles they aren't nearly as good, and anything after that, they're basically shot.
St. Jude Donor '08-'09-'10-'11-'12
I'm approaching 13,000 mi on my '08 and am at the point where I need new tires. Just normal driving, occasional spirited acceleration. I'll be trying the Michelin PS2 ZPs soon.
8,663 on my Stock GY's before I swapped to INVO's
fronts were just below the wear bars, rear where also, with the "belts" showing on parts of the rears.
I got 12,000 miles on mine.....could have gone another 1,000 but not worth the risk. Never know when spirited driving is called for.
Just put on 4 new Michelin PS2's today.
_"SCOTT"_
C2 of the Year Finalist - Unmodified 2020
Have over 13K on mine, changing the rears this week being I have off work. picked up a set of new ones last year. Could get another 1K OR 2 BUT WOULD RATHER HAVE BETTER RUBBER ON FOR THIS UP COMING SPRING SUMMER!
I got 11K on my first set..maybe 13K on my 2nd set maybe 12K on 3rd set...just switched to the General UHPs....so far its a whole new car. I can actually drive in the rain and accelerate from a light when the road is wet. Dry traction is worlds better and I expect to get way more than 11-12K out of these. The stock tires sucked after 4-5K. When you only start with 8/32 tread depth it doesn't take long to see traction diminish. I have no clue how anyone can get more than 11-13K out of a set unless you milk 'em down till they are bald.
I drive a 2005 C6 Corvette with the Z-51 suspension. At 28,500 miles I replaced my OEM Goodyear tires, which still had decent tread, with Michelin PS2 ZP run flat tires in hopes of a quieter, less harsh ride without sacrificing grip and treadwear. After having the tires installed, I immediately went on a 3,500 mile trip where I experienced both wet and dry summer driving conditions, and I found the Michelins to be a superior tire to the OEM's in all respects. I would highly recommend switching to Michelin, if you're looking to replace your OEM's.
Don
