C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Katech tests Halltech's new intake systems on the engine dyno
Old 03-10-2010, 12:58 PM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
Default Katech tests Halltech's new intake systems on the engine dyno
We recently got a chance to test Halltech's new air intake systems on the engine dyno. We performed 3 sweep tests per intake allowing the temperatures to equalize between runs. I chose the best run for each intake and put them in the graph below. The second graph is the same thing, just on a different scale so you can see the differences in the intakes better. When dealing with these slight variations, it's difficult differentiate. For example, the difference between the new plastic Killer Bee and the carbon fiber was 1hp. Well below a normal dyno variance. One horsepower is .1%. I call that a virtual tie.
C2-8843 (red) - Stock LS7 airbox
C2-8847 (green) - Original Halltech Killer Bee (plastic)
C2-8850 (blue) - Halltech Killer Bee II Carbon Fiber (112mm)
C2-8855 (black) - Halltech Killer Bee II Plastic
The test subject was the latest 2010 Street Attack LS7 with:
Torquer LS7 camshaft
11:1 compression
WCCH ported heads
FAST LSXR 102mm intake
Nick Williams throttle body
ARE stage 3 dry sump system
I welcome any intake manufacturer to send me their system and we will do the same test free of charge.
__________________
Contact:
(e) zach@katechengines.com
Old 03-10-2010, 01:39 PM
0Adam at RSI
Former Vendor
Adam at RSI's Avatar
Thanks for the Test Results!
Which intake do you run on your Z06?
Have a good day Jason!
Old 03-10-2010, 01:46 PM
Katech_Zach
I was running the gen 1 Halltech Killer Bee carbon Fiber and I'm switching it to the new Halltech Killer Bee Carbon Fiber 112.
Old 03-10-2010, 02:01 PM
obzidian
obzidian's Avatar
St. Jude Donor '09
Two things:
1. The CF is a larger intake than the KB 2?
2. So that rise in power at the very end of the hp curve (6100-6500) is the 1hp variance that you are dismissing as a "virtual tie?" Or are you talking just about the peak hp figures? Because that looks like a significant, when comparing intakes anyways, gain that helps keep that power-curve ballooned, not dropping.
Old 03-10-2010, 02:06 PM
Katech_Zach
Originally Posted by obzidian
Two things:
1. yes
2. Look at the scale. This is zoomed in so we can see 1hp differences. It's not that significant.
Old 03-10-2010, 08:51 PM
obzidian
obzidian's Avatar
St. Jude Donor '09
I see a 3hp difference!!! Nothing you'll ever notice but its something!
Old 03-10-2010, 08:56 PM
Katech_Zach
Every little bit helps right.
Old 03-10-2010, 09:00 PM
HP ADDICT
HP ADDICT's Avatar
So on a 600hp motor the KB2 makes about 3-4hp more then the KB1?
Old 03-10-2010, 09:05 PM
Katech_Zach
Yes, on a tuned engine the direct filter vs. filter difference is about 3hp. However, on a bone stock engine with no tuning, the differences between a stock filter and the new KB2 will likely be greater. More to come on that later.
Old 03-10-2010, 09:14 PM
EVILNESS
EVILNESS's Avatar
HOw did u tune the TB? Any tips for us who havent got it to run right?
R.
Old 03-10-2010, 09:23 PM
Katech_Zach
R.
We're running mechanical on the dyno. Nick Williams has some tips. I'm sure if you email him he'll walk you through it.
Old 03-10-2010, 09:43 PM
EVILNESS
EVILNESS's Avatar
Tried that and nada...
Old 03-10-2010, 09:56 PM
molon labe
molon labe's Avatar
very interesting data. thanks for sharing!
Old 03-10-2010, 10:57 PM
kumar75150
kumar75150's Avatar
well i ordered one along with the NW 102mm TB last week
let's see how much hp i get out of $1150 bucks
Old 03-10-2010, 11:43 PM
dvandentop
dvandentop's Avatar
Let us know for sure
Old 03-21-2010, 01:43 PM
Halltech
Supporting Vendor
Halltech's Avatar
St. Jude Donor '09
Default Halltech's Super Bee™CF112 Carbon Edition is onsale through March only
  • +33 RWHP/26 lb-ft Tq. with recalibration of MAF tables only on 91 Octane Fuel vs. stock (Test Vehicle 2010 Z06 with 10 miles, just off the carrier)
  • +14 HP on the Katech Superflow Engine dyno over GM stock LS7 intake
  • Mass Air Flow Sensor relocation under the Super Beehive™ Heat Shield/Radiator Bezel
  • Zero Obstruction to flow at the throttle body
  • 112mm outlet to match the new Billet WP 102mm Throttle Body and FAST intake manifold
  • 112.5mm inlet from the all new Killer Bee™ II filter
  • Relocation of the Dry Sump vent tube to the filter bottom
  • Larger plenum and redesigned flow design by Jim Hall
  • Built in Velocity Stack Bellmouth filter flange
  • More Horsepower and torque than any other intake made for the Corvette
  • Pure Carbon Fiber made by the company that makes Pratt & Miller C6.RS body panels
http://www.halltechsystems.com/Hallt..._p/sbcf112.htm
Dyno done on a brand new 2010 Z06 with minor MAF recalibration and on 91 Octane. SAE 12.2:1 Air fuel ratio and 22 degrees timing:
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
Old 03-21-2010, 08:11 PM
HyperX
HyperX's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
So the moral of the story is find the gen I intake on ebay?
To Katech tests Halltech's new intake systems on the engine dyno
Old 03-21-2010, 08:36 PM
08jetvette
08jetvette's Avatar
I might have one for sale in a couple of days.
Old 03-22-2010, 11:00 AM
skudlw
skudlw's Avatar
Not impressive for the money one would spend on the change and potential warranty issues.
Old 03-23-2010, 05:19 AM
foremaw
Support Corvetteforum!
foremaw's Avatar
St. Jude Donor '08-'09-'10-'11-'12
Quick Reply: [Z06] Katech tests Halltech's new intake systems on the engine dyno
