C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Mount Front License plate on c6 z06
Old 12-22-2009, 04:44 AM
Hirohawa
Hirohawa's Avatar
Originally Posted by The NNIAL8R
Very easy..about 10 minutes....No drilling, etc....but it helps to get the car up on a lift as the nose sits so low ..
Thanks!
Old 12-22-2009, 09:29 AM
joe@zip
Platinum Supporting Vendor
joe@zip's Avatar
Originally Posted by Undy
I've had the Zip bracket for 3 years, 50K miles, and it's top notch..
Thanks! We have sold and installed a lot of these and every customer comes back telling us how much they like them.
__________________
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles
Old 12-22-2009, 09:54 AM
NHRA95
NHRA95's Avatar
It would be nice if Zip Products would offer us forum members a discount on this item. Maybe running a group purchase?
Old 12-22-2009, 09:57 AM
jlutherva
jlutherva's Avatar
Any air flow that gets blocked is not an issue on streets or highways. If you are doing a lot of driving in the 120+ mph region then it might be an issue. But then you can remove the plate. It will not be an issue on a road course as they don't require plates and if you are doing those kinds of speeds on the road the lack of a plate will be the least of your problems.
Bill
I was skeptical about putting such a large blockage in front of the main air inlet; however I have found it makes no significant difference on the highways, even on warm days. On the other hand, it helps to warm the oil quicker on cool/cold days.
For track days, it comes off.
Cheers,
Jim
Old 12-22-2009, 10:05 AM
joe@zip
joe@zip's Avatar
I will look into offering a group purchase and let you know.
Old 12-22-2009, 02:14 PM
vetdude
vetdude's Avatar
Originally Posted by LEJ ZO6
I highly recommend moving to Florida. We don't run front plates.
Oh, Yea, I almost forgot ... we don't have winter either.
But, you've got thousands of gray-heads, hurricanes, 100% humidity and bugs the size of Hondas - I'll take the front plate.
Old 12-22-2009, 03:38 PM
Top Flight Reproductions
Top Flight Reproductions's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by vetdude
To all the "Doubting Thomases" out there: I've been running the removeable front license bracket from www.topflightrepro.com (yes, MD is a two-plate state and the LEOs look for that damn front tag all the time) since I took delivery of the car in 2006 and have experienced no over-heating or other cooling issues whatsoever when running the front plate, even in 100+ degree weather with the a/c running. These are still Chevys engineered and built for the street, not NASCAR COTs or F1 Ferraris.
Cheers,
Jim
As I said on the street it really isn't an issue. It isn't an issue on the drag strip either as the car doesn't run long enough for it to be an issue. The cooling air intake is designed to cool the engine when it is producing max power for sustained periods. If you aren't doing that the plate will not block enough air to cause a problem.
Bill
Thank you all. There's a few reasons why The Top Flight Reproductions Front License Plate Bracket is so popular here on this forum:
1. No adverse effect on cooling
2. Hands down the best looking solution available for the C6
3. Very easy to install
4. And we have them In Stock
Old 12-22-2009, 05:25 PM
bigwoolyg
bigwoolyg's Avatar
I like that.. do you guys have IT work?
I haven't put a front license plate on any of my cars, I'm in NJ. I have had two tickets in the past 20 years for this. Once in my camaro, once my BMW was ticketed in a train station parking lot. The second one was a pain, mandatory court appearance where I had to dance around and tell the judge I was getting it installed. Of course, I didn't show up in the car missing the plate, and now I don't take the train from that town (because of the ticket, I take it in the next town down the line). I should move to a less authoritarian state than NJ... Even PA.
I'll never put a plate on the front of my Vette.
Old 12-23-2009, 03:53 AM
Hatdude
Hatdude's Avatar
Originally Posted by snide
My front plate is in my garage somewhere on a shelf. It think.
I know exactly where mine is.. in a pile with all the other front plates from my other cars over the years.
Old 12-23-2009, 04:33 AM
MarkRx
MarkRx's Avatar
Top flight is the best IMO. looks great, easy to remove for shows, and very well made. You get what you pay for! /close thread
Old 12-24-2009, 03:22 AM
Lead Foot 66
Lead Foot 66's Avatar
Ditto. WA is also a 2 plate state, and some of the LEOs look for front plates. So I use the Top Flight removable unit and it is excellent.
Old 12-24-2009, 02:41 PM
Hirohawa
Hirohawa's Avatar
How do you remove the Top Flight plate?
Old 12-27-2009, 10:58 PM
  #33
Lead Foot 66
There is a bracket affixed to the car which the license plate (and backing plate) screws onto via 2 wing nuts.
So to remove the license plate, simply take off the wing nuts and the license & backing plate plate simply come off.
I have been very satisfied with this very well made unit.
Contact Jim @ Top Flight Reproductions if you have any questions. They very good folks to work with.
Old 04-15-2010, 09:35 PM
  #34
749duc
Cruising
749duc's Avatar
Default First ticket
Just got my first ticket for failure to display a front license plate
I ordered my Zip bracket tonight. Should've done it sooner!
Old 04-16-2010, 08:41 AM
  #35
joe@zip
joe@zip's Avatar
Thank you for your business, let us know how you like it!
Old 04-16-2010, 09:49 AM
  #36
bigterpsfan
bigterpsfan's Avatar
Got one on mine!!...Quick release bracket means it's on & off in less than ten seconds
I have the same thing - off and on in less than 5 seconds - can't even tell the bracket is there unless you are looking for it!
Old 09-09-2016, 04:05 PM
  #37
Pazetronics
Pazetronics's Avatar
Here was my solution, no more scraping the plates with curb/speed bump
Old 09-10-2016, 11:09 AM
  #38
dmuellenberg
dmuellenberg's Avatar
https://youtu.be/ZZ2U64UqwbE
The video shows it on a base C6, does it also work on the Z06 (since this is a Z06 forum)?
Old 09-13-2016, 12:52 AM
  #39
BadboyZ06
BadboyZ06's Avatar
Here is another option I found a few years ago, when I got a warning for no plate and a ticket for tinted windows... I purchased one and only installed it for the LEO inspection and it has not been on the car since. I had my windows re-tinted after the inspection.No drilling is required but I had to open up the bracket holes a bit to fit well.
http://thedoubleaa.com/cart/index.ph...roducts_id=140
Quick Reply: [Z06] Mount Front License plate on c6 z06
