C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Blown Motor
Old 11-30-2009, 09:06 PM
ratt_finkel
ratt_finkel's Avatar
Default Blown Motor
For those that care.
Car is 2008 Z06. Daily driver. 31,xxx miles.
Bone stock motor.
Headgasket went, which mixed oil and coolant starving the bearings on cylinders 5 and 6.
Engine will be covered under warranty.
Car was being "driven", under load in 1st gear when this happened.
Old 11-30-2009, 09:14 PM
jjjflex
jjjflex's Avatar
Dammm
Good for you that its "Under Warranty"
Goodluck!!
Old 11-30-2009, 09:16 PM
dwiemers
dwiemers's Avatar
Yeah good that the warranty is still there!! I have the same car and it's a DD, makes me wonder.... :/
Old 11-30-2009, 10:01 PM
rws.1
rws.1's Avatar
sorry to hear about your problem.
Glad to hear it will be repaired... under warranty.
Old 11-30-2009, 11:06 PM
06-Z0SICK
06-Z0SICK's Avatar
I cannot believe how fragile these things are. GM should have built these a little more reliable like the LS1. You could throw anything at an LS1 and it will live, big cams at 100k miles, nitrous, etc
Old 11-30-2009, 11:08 PM
MachAll 2005
MachAll 2005's Avatar
Bone stock motor.
What was your "Daily Drive" like .... how many miles and stop & go?
Old 11-30-2009, 11:54 PM
ratt_finkel
About 4 miles a day. Maybe 3-5 stops depending on traffic. 35-45mph zones.
I have taken the car on several road trips this year (bought in January). Including a trip to Vail, CO and back. About 1800 miles without a hickup.
Old 12-01-2009, 12:15 AM
GMuffley
GMuffley's Avatar
Good that your engine was not tuned or modified internally.
Old 12-01-2009, 01:02 AM
UR2SLO
UR2SLO's Avatar
glad to hear its being covered. My bone stock motor blew too, except mine broke a valve spring then dropped a valve into the cylinder shattering the piston and cracking the block.
Old 12-01-2009, 09:12 AM
walterm32
walterm32's Avatar
OP: I'm glad your warranty in intact and it will be covered.
A blown head gasket could do this to any car. It has nothing to do with as you say "how fragile these things are".
Old 12-01-2009, 10:17 AM
1.8t
1.8t's Avatar
I am thinking more along the lines of oil starvation than blown headgasket. Blown head gaskets are almost non-existent on n/a vehicles, much less LSX ones. The stock head bolts on these cars have been used for 800+whp setups MANY times. The main reason people swap to ARP studs or bolts is because they can be re-used over and over since they aren't TTY like the stock bolts are.
The car was bought used correct? Wonder what the odds would be the previous owner tracked the vehicle?
Old 12-01-2009, 10:21 AM
HyperX
HyperX's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
I dunno if going from my rock solid LS2 to LS7 was such a great idea. It seems a lot of people have engine issues. I hardly see any LS3 or LS2 engine issues. Maybe I need to extend my warranty.
Old 12-01-2009, 10:31 AM
Joe_Planet
Joe_Planet's Avatar
the new 2009 engines fix pretty much all problems that the previous engines had and its covered under warranty, so there's really nothing to worry about. just dont mod it out and you're fine
Old 12-01-2009, 11:13 AM
HyperX
HyperX's Avatar
I got a great deal on a 2008, so I am in the 2008 boat. Oh well. I will get extended warranty and hope for best. Just scary about how fragile the LS7 is.
Old 12-01-2009, 11:21 AM
1.8t
1.8t's Avatar
The 2008 comes with a 5yr/100k mile powertrain warranty. How much would you need to extend??
Old 12-01-2009, 11:33 AM
HyperX
HyperX's Avatar
Depending how much it is, as long as possible. I wanted to keep the Z06 as a car I would eventually give my son (who is 4 now).
Old 12-01-2009, 12:32 PM
1.8t
1.8t's Avatar
Wow. *Crosses fingers you won't make it his 16th birthday present*
To Blown Motor
Old 12-01-2009, 12:33 PM
HyperX
HyperX's Avatar
No, more like 24th. He is going into the Marines like his dad first. Mandatory family commitment.
Old 12-01-2009, 12:34 PM
SS MPSTR
SS MPSTR's Avatar
It's a hand-built high performance engine....what do some of you expect? It is as reliable as can be expected, comes with a warranty, and makes more power than any previous N/A production engine GM has ever produced - and it passes strict emissions standards!
Fragile? I don't even know what that means. Exercise warm-up procedure, maintain it like it should, and listen to when it's telling you something is amiss, and you'll get years - if not decades - of enjoyment out of this engine. If you mod it, realize that it stands a great chance of an abbreviated life. That's life in the world of modified high performance engines/cars - not "if" it will break, but rather "when".
Old 12-01-2009, 12:53 PM
1.8t
1.8t's Avatar
In that case
Quick Reply: [Z06] Blown Motor
