[ZR1] Launch Control Comments?
Cruise-In 2, 9 & 10 Veteran
St Jude donor '09
Anyone here with a 2010 ZR1 use their launch control feature yet?
Comments appreciated.
Launch control
I haven't even gotten into 4th Gear much less use the Launch Control herr in NY.......I am sure I will never get to use that Feature here because if I do I will be in the Trunk of the car in front of me....Harvey
Ha ha ha! You are very funny but absolutely 100% true!!!
Full size member
Wow, I can't even possibly imagine that. But, I'm used to the open roads here in Texas. Come on down here Harv.
St Jude donor '09
St Jude donor '09
I will break it in as per the manual. No hard starts or stops. No cruise control, vary the engine rpms and speed, row thru the gears. In a nutshell: do not keep the engine speed/load at a constant level for the first 500 miles. Keep away from red line.
I worked in the engineering lab at Detroit Diesel for over 35 years. Can't remember how many different engines I ran thru the years. 2 stroke, 4 stroke Detroits, and numerous experimental products. Basically the same techniques were used to break in a "green" engine.
Received 3,844 Likes
"Ask Tadge" Producer
jas
St Jude donor '09
I did drive it across state lines last weekend for the NCM Anniversary, and plan on driving her to Brasselton GA in couple of weeks for the ALMS Petit LeMans.
Sorry to hear..... there is no quicker way of making yourself "feel" better than flooring your zr1 and hearing the valves open and feeling the vibrations in your seat! Take care
I tried mine,it seemed to really limit the power,like leaving traction control on in my Z06.I guess it was working, the tires didn't spin much at all.
Luweegy- did I understand your Z06 has reduced power when TC is on in normal driving mode...mine is opposite...when I turn the TC off the car definitely has reduced power getting to the rear wheels...any thouhgts? thx Don
Don, the lauch control posistion on my Zr1 feels just like leaving my Z06 traction control on and trying to do a burn out.I'm not I've never heard of your problem? You might do a post in Tech&Performance.
