[Z06] Race Proven Motorsports Cam Only 10.47@ 137.8
C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
so the only major mod other than headers is this cam? stock gear and trans? what is the weight of the car and how do you get those trap speeds with only a cam??
I was thinking the same thing. Looks like the 325/45/17's are almost 2" taller then stock, that with another few hundred rpm and I guess it can be done. Nice job guys .
That is correct.
RPM Built trans and an RPS Street Twin Lite Clutch.
The whole crossing the line in 3rd gear was a spur of the moment thing. i looked down and saw 7K RPM, looked up and saw the quarter mile pillar coming up, decided to go for it..was probably around 7300.
Good sh*t. When the air gets better you'll likely have shift to 4th unless your tuner wants to keep bumpin the limiter.
