[Z06] Rocker Arm failure with a twist
Former Vendor
Modified engine (not by us). It ran very strong for a long time, then... Heads are not ported. Intake side. Spring pressure isn't a crazy amount either. Have you guys been seeing this?
Did you check if the bolt is the right one? it might have been a wrong bolt and a shorter bolt means it wont grip in the more meaty area. Or they might have torqued too much. Or that rocker is very loose and it had too much play which caused more impact. or it was simply a defective cylinder head......or the world may never know haha
Yes i have actually seen a car do something like that except it broke into the intake port. Stock head also. Manley nextek springs and a 242/254 cam. It did it in the EXACT same spot on both heads. Right through the GM casting mark.
Former Vendor
Rocker was tight, right bolt and everything else seemed to be in-line.
Randy
Nothing that a tube of JB Weld couldn't handle.
I thought the stock bolts threads extend all the way to the tip of the bolt, 3 heads swaps will familiarize you with parts as you are cleaning them prior to re-install.
I've got some great pics of my failed INA bearings ( at work)
another reason I'm glad I went smaller with my cam.
Could it be a flaw in the drilling and tapping of the head? It looks like scuffing on the rim of the bolt as if it was bottoming out in the head causing it to separate. In other words, maybe the hole wasn't quite deep enough.
Former Vendor
Very interesting. It would be interesting to know if your failure and the one Frans96ss saw were on the same cylinder. It might also be interesting to Zyglo the rest of the stands on the failed head and, if the customer is up to the guff, the unfailed head.
Castings are brittle (ewe all knew that) all it would have taken was a small casting flaw or even a void in the casting to cause this. Notice the angle on the corner closest to the camear that tells me the casting falw was aroiung that point at the corner the casting cracked then in typical Aluminum Casting brakes the brake followed a stright line basted on the last thread of the bolt.
But what do I know I only work with missiles not engines....
1 Post
Any signs of prior valve-float? Harmonics can be at work here. I was running stock modded H.S. rockers and broke a rocker bolt......but was able to drill/easy-out the bugger and I put the shaft units back on. BTW, 420# open spring pressure here, but I had an fast ramp-rate cam at the time. My head did not do that, but they are not stock castings.....
