[Z06] Race Track Video..Z06 vs Porsche 996 turbo
Here is a link to some footage from Pueblo Motorsports Park. I was in my Z trying to keep up with a Porsche 996 turbo. The all wheel drive P car was on Hoosiers and I was on Bridgestone Pole Position run flat street tires. The turbo all wheel drive had the advantage hooking up the power and the traction, coming out of the corners, and had more power than my Z.
I knew the fastest line and the braking zones a little bit better than he did, since this is my home track. You will see me almost loose it on lap 2 in the hairpin ( I got a little high up into the marbles), but I gathered it up and ran him down.
At the end of the long straight we were doing between 138 and 142mph
http://www.youtube.com/watch?v=_hZMxj8Ytf8
Thanks for sharing, you mentioned that the 996 had a bit more power, was it tuned?
B&M on the left..OEM on the right.
You can see the B&M has just a slight bend in the shaft (right at the pivot point), position it forward and it moves the stick almost an inch forward as compaired to the back angle. You can see how radical of an angle the OEM shifter has. OEM throw is 4 1/2 inches and the B&M is only 3 inches.
B&M Ripper short shifter
Nice driving. It was fun to watch!
Jim
Seems to me the price difference between the two cars, the Vette held its own. Had the Vette been on Hoosiers.....he may have done better. Was the Vette stock, engine and suspension. Hhat was the HP on the Porsche?
Most of my mods so far have been safety related, not more speed.
List of my mods so far;
Pfadt Chassis Stiffening Roll Bar
Recaro Pole Position seat
Hardbar seat belt bars
Pfadt race seat mounting kit - with slider
Schroth Hybrid 6 point harness
Sabelt shoulder belt pads
DBA front rotors
Cobalt GTS 1 piece racing brake pads
Quantum brake duct hoses
Goodridge G-Stop SS braided brake lines
Hardbar Delrin shifter ****
Skip Shift eliminator
Mild 2 Wild exhaust controller
Elite Engineering PCV oil Catch Can
Elite Engineering Heel-Toe Gas Pedal
Phoenix Performance Tow Hooks
Thermo Shield Ball Joint and Tie Rod End Insulators
Muffler Mod
B&M Ripper Short Shifter
Maxx
Great news on the B&M. I have one on order.
I will look at the fitting options and if suitable for me, will reverse the lever as you did
Thanks for that
What is the "heel-toe" gas pedal?
John
Thanks for that
John
Heel toe gas pedal from Elite Engineering
http://www.eliteengineeringusa.com/C6_Pedals.html
And that Porsche was certainly powerful.
BTW enjoyed the video, thanks for the post.
do you heel and toe or do like i do and use the right side of your right foot to blip while left side to brake? i have a hard time twisting my foot around to blip, my legs are too long (6 foot tall).
Excellent driving
Maxx,
What tire pressures are you running at the track?
I'm doing my first HPDE with the Bridgestones in 2 weeks.
I was running 28psi hot on the OEM Goodyears.
Jonathan
Jonathan
