[Z06] 2008 Z06 Horn Alarm started goin off on its own
I washed my Z06 this morning and let let is sit half a day before waxing it. It is a 2008 2LZ with 1500 miles. While I was getting ready to take my wax off a few hours after the wash, the alarm started going off on its own. I didnt have it set, the fob was in the car on the seat and the doors were unlocked initially. Well I couldnt get it to shoot off no matter what I did with the fob so I opened the trunk and took the negative terminal off of the battery. I let is set a few mins and hooked it back up and it started again. I unhooked it again for about 5 mins and hooked it up and it fixed it I thought. The car starts, the doors lock etc but my horn wont work and my alarm when I set it wont chirp my horn. At first it did and the horn sounded sick or something, kinda like it was half as loud as normal when you set the alarm but than it quit altogether. So basically I can start my car and drive it, lock my doors from the fob but I have no horn at the steering column and no chirp when I lock my doors from my fob. Anyone have any ideas at all. Yes I squirted the engine compartment lightly this morning and probably got something wet, but the fuses and relays are all covered. Any help would be appreciated. Thanks
But same as you it was parked up after being washed and the alarm was going off.
I had this a few weeks ago. Aparently a not too known problem with these is that if water makes it to the top/main horn then it causes a short. Firstly have a look at the fuse. Mine was blown but then I also had to have the horn replaced but they did it under warranty.
