[Z06] Different colors on HUD???
I am sure it is possibly, but based on what I know about the HUD it is a florescent display and the filter inside is green, there is know way I know of that it can change color unless it was say OLED, but back in 2005 when the C6 was introduced OLED was not available commercially yet. It could have a filter over it, but florescent displays are a light blue natively, and the green it obtained by a filter, you could maybe replace the filter with a red one, but it would be a real pain to do because you would have to disassemble the unit down to the bare glass display. Maybe someone here has some pictures of the HUD disassembled and maybe we can take a look for sure. Sure would be neat for it to change colors though.
Lysergic acid diethylamide, a semisynthetic chemical compound of the ergoline family. While a single dose of LSD may be between 100 and 500 micrograms — an amount roughly equal to one-tenth the mass of a grain of sand — threshold effects can be felt with as little as 25 micrograms. Generally, the dosage that will produce a threshold psychotropic effect in humans is considered to be 20 to 30 µg.
Some psychological effects may include an experience of changing colors. man
St. Jude Donor '09-'10-'11
Yellow Jacket is spot on, there are vacuum florescent displays or VFDs. They emit light in the blue green spectrum so red would not be an option without a special filter. THe VFDs light emssions is what drives the display, LCD and OLEDs are not bright enough to act in HUD displays unless you are projecting a strong backlight through the display.
Jay
Jay
Premium Supporting Vendor
Most BMWs have red dash lights at night. So do jet fighters. Some study showed that red instrumentation was the best color for preventing fatigue and for best contrast.
I have a '06 Z06 and a '06 BMW M6.
The M6 does have color HUD, which is pretty cool looking, but it is not as flexible as the Z's. You can't pick and choose different modes or different info to have "beamed" to you. It's only the tach, gear and MPH, if I'm not mistaken.
Although only monochromatic, I like all the info on the Z's HUD and the flexibility much better.
Maddyk,
Welcome to the forum. Open is open. is . This forum has been around long enough to vet (pun) out most of the misinformation. Most of the guys on here are VERY knowledgeable and straight forward. Use them wisely but still use them.
Gary
Gary
#34
Red is used in situations where night vision is required such as on submarines. The transition from looking at a red light illuminated object to seeing in darkness is easier then with other colors. For a car this means you can look at red back lit instruments and then peer down the road with not so much loss of vision. It's not a night and day difference with respect to other colors, just a little better for most humans.
