[Z06] Proper air pressure for......
Nitto Invos? Do you still stick with the OEM 32 psi? I just got a set of 345's for the rears and 275's for the fronts (19's and 20's) and someone was telling me to run 40, what are you guys running?? I am talking aboout for normal street use!!
I run mine 30 psi cold. I have the same sizes. Anyone ever ask Nitto directly what they recommend? 30psi cold is no doubt for the factory runflats, not necessarily Nitto Invos.
I have the same question, running 32 PSI right now, but I heard it should be higher.
I have an 07 with 5K miles and noticed a bit of feathering or cupping on front. I run 35 pounds...but maybe I should go with the recommended pressure?? How can I prevent uneven tire wear on those front tires? And how do I know if it needs aligned. Is there a site I can go to for pics of uneven tire wear so I can see what action to take??
Buck in Virginia
Buck in Virginia
Buck in Virginia
Buck in Virginia
I'm guessing your alignment is off, because with 35 pounds you should be seeing extra wear in the center of the tire if the alignment was good.
The auto manufacturers door jam pressure is low on many cars to give a better ride. I'd like to think that is not the case with a Z06.
Perhaps you could help me with information on proper pressure for both street and track. I am on the OEM tires and I'm entering my first autocross next weekend. What should I run there? What pressure would recommend for the street.
TIA,
Eric
TIA,
Eric
