C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Z06 Aluminum Frame Repair Procedures?
Old 03-13-2009, 06:39 PM
PaceThis
PaceThis's Avatar
Default Z06 Aluminum Frame Repair Procedures?
Hi all,
I have a 2008 Z06 that took a light hit in the rear. At a minimum, it will need a new rear cross support, though the rear rails may be shifted slightly, it'll have to be measured to see exactly.
Does anyone know the repair guidelines for this frame as it's aluminum? Can rails be "pulled" to a minor spec if needed (and assuming no kinks or bends anywhere in them)?
Any info on the aluminum frame repair is desired. I'm not asking for opinions on repairing the vehicle, it's very light damage and will be repaired. Just wondering if the rails are slightly out of alignment if they have to be replaced, or can be pulled to spec.
TIA,
Josh
PaceThis is offline
Old 03-13-2009, 08:01 PM
ZPO
Support Corvetteforum!
ZPO's Avatar
If I'm not mistaken, the frame repair procedure is outlined in the GM service manuals. Unfortunately, I'm not near my manuals at this moment to verify.
ZPO is offline
Old 03-13-2009, 10:17 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
You need special welding equipment and a special welding room to do aluminum. Very few body shops are aluminum qualified these days.
Cobra4B is offline
Old 03-13-2009, 10:21 PM
davidfarmer
davidfarmer's Avatar
I saw the video of the Z06 frame being built......no special "room" needed to weld a rear cross bar on, but you do need someone competent with aluminum.
If it really was a light hit, I bet the frame rails are fine. The inner tunnel, as well as the rear subframe, do a great job of strengthening the rails, although the rear connector is easy to "squash", or at least bend the outer arms forward.
If it does happen to be bent, I'd have them pulled if it is just minor. Sleeving and welding an entire frame section in place is just asking for problems. Once the rear bar is off, bending each side should be easy for a frame machine. Whether or not heat should be applied is the question, and as above I'd suggest checking the repair manual.
davidfarmer is offline
Old 03-14-2009, 01:16 AM
Tamulinas2
Tamulinas2's Avatar
Hi Josh:
Do not heat or bend aluminum! It is brittle and will crack. A towing company bent
the frame on my Z06 and I went through this extensively with the insurance company. (They bought me a new Z06)
Check http://www.goodwrench.com/gmgoodwren...=Corvette_(Z06)
It's a pain but you cannot heat and bend like steel. It's cut and replace.
Good luck.
Stace
Tamulinas2 is offline
Old 03-14-2009, 08:45 AM
dollarbill
dollarbill's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11
While I agree with Stacy on Aluminum not bending and pulling well, I found this below in the manual on a rear frame rail end replacement. It also showed the butt replacement method using a sleeve insert and welding the new section on. Look at this from the manual Z06 rear end replacement procedure:
Caution: Refer to Approved Equipment for Collision Repair Caution in Cautions and Notices.
1. Disable the SIR system. Refer to SIR Disabling and Enabling.
2. Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection.
3. Remove all related panels and components.
4. Remove the rear impact bar. Refer to Rear Bumper Impact Bar Replacement.
5. Note the location and remove the sealers and anti-corrosion materials from the repair area. Refer to Anti-Corrosion Treatment and Repair.
6. Repair as much of the damage as possible to the factory specifications.
7. Use J 42058 to secure the vehicle if pulling and straightening are required.
dollarbill is offline
Old 03-14-2009, 09:22 AM
ipmtim
ipmtim's Avatar
Cruise-In VIII Veteran
St. Jude Donor '06
Why would you need a special room?
I've been welding aluminum for 25 years in my plain ole' shop.
I think that most body shops aren't set up for welding aluminum because 98% of cars are steel not aluminum frames.
ipmtim is offline
Old 03-14-2009, 11:26 AM
Cobra4B
Cobra4B's Avatar
You need to have a seperate area and equipment to weld aluminum so that you don't contaminate the welds. Jaguars still use lots of aluminum and finding places to get them fixed properly is getting harder and harder. In our area (a big populated area) only one body shop gets all the Jag work.
Cobra4B is offline
Old 03-14-2009, 02:19 PM
davidfarmer
Most aluminum is not brittle at all, but I do not know what type the frame is made of. If that is the case however, then if the frame is already bent, then it is already likely cracked, and will require sleeving.
if it was my car, I'd still try and pull the frame before cutting it in half and sleeving it. I certainly wouldn't sleeve my frame if the incident really is as minor as it souns.
When the C5 first came out, everyone said the hydroformed steel frame could not be pulled......
I agree that the hardest part of ANY welding is prep and cleaning.....so yes you need the right equipment and clean parts, but not some sort of "clean room" as I thought you meant.
Old 05-25-2009, 04:47 PM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
good question, I don't know of any other car that uses an alum frame? a bunch use it for unibody and the euro stuff gets a lot of box tubing????
SteveDoten is offline
Old 05-25-2009, 05:49 PM
dvandentop
dvandentop's Avatar
audi a8 uses alum frame
dvandentop is offline
Old 05-25-2009, 07:59 PM
burnout1464
burnout1464's Avatar
St. Jude Donor '10
I have bought salvaged corvettes and still will, but i must tell you first HAND you gotta find a PROFESSIONAL WELDER AND FAB MAN, if not you will make a mess. Good Luck.
burnout1464 is offline
Old 05-26-2009, 09:44 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Vipers, some of the range rovers, there is a few dump trucks and heavy equipment going to Alumium.
Randy
Randy@DRM is offline
Old 02-02-2011, 04:09 PM
mp3plc
mp3plc's Avatar
Originally Posted by PaceThis
Hi all,
TIA,
Josh
Hi Josh, I was wondering if you can share your experiences with the frame repair work?
Was the frame actually bent? did require welding, etc?
thank you for any useful info, I am in the same position you were.
mp3plc is offline
Old 02-03-2011, 09:30 AM
KanuckZ06
KanuckZ06's Avatar
Jag type X cars are all aluminum, use one of thier approved repair shops.
As always, proper preperation is key to a good repair.
KanuckZ06 is offline
Old 02-03-2011, 09:57 AM
Z11409
Z11409's Avatar
Aluminum in its pure form is not strong enough for use in structural parts. Other elements such as copper, magnesium and zinc are mixed with aluminum to alloy it, thus making it stronger. Alloyed aluminum is grouped into two categories: heat-treatable and non-heat-treatable. The heat-treatable group includes: 2000 series (alloyed with copper) used often for body panels; 6000 series (alloyed with magnesium), also used for body panels; and 7000 series (alloyed with both zinc and magnesium, making it very strong), used for applications such as bumper reinforcements.
Z11409 is offline
Old 02-03-2011, 11:07 AM
TxPres
TxPres's Avatar
Good information!
Any idea which category our frame is in?
TxPres is offline
To Z06 Aluminum Frame Repair Procedures?
Old 02-03-2011, 02:45 PM
jimbo2golfgolf
jimbo2golfgolf's Avatar
More than likely Grade 6061-T6 as this Grade is for structural applications, The highist strength alloys are 7075-0 and 7075-T6 these are used primarily for aircraft, 7075 Grades do not have good welding properties
jimbo2golfgolf is offline
Old 02-03-2011, 03:43 PM
NORTY
NORTY's Avatar
The Dana made aluminum frame is~
274 lbs.
2. Rails: are AA6063-T5 (4MM) and weight 77 lbs each
3. Extrusions: are AA6063-T5, T6 + AA6061-T6 (21 of 'em.)
4. Sheet stampings: AA5745-O
5. Castings: A356-T6 (8 of 'em.)
Also:
The front cross member is MAG. It's type is AE44
All this info (and tons more) is found in the FAQ section for Z06's right here in this forum!
NORTY is offline
Old 02-03-2011, 06:19 PM
Tact
Law Dawg Moderator
Tact's Avatar
CF St. Jude Co-Organizer
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
http://forums.corvetteforum.com/foru...s-or-more.html
Tact is offline
Quick Reply: [Z06] Z06 Aluminum Frame Repair Procedures?
