[Z06] Shocks, Penske vs Moton ?
I have Pfadt coil overs now but I want to get something more hardcore w a reserve
So supposing I do at least 20 track days a year w my Z which would be the better shocks ?
Premium Supporting Vendor
I'm partial to Moton. Very happy with mine.
I can't argue with Jason. I have driven cars with both and I don't think you can go wrong with either one. I personally lean toward Motons.
Jim
Jim
Former Vendor
I run Penske on my car and love them. Since they are inverted, I was having trouble with them tearing the rubber boot on the axle. Of course the solution was to put a tie wrap around the boot and squeeze it a little, no problems since. Moton mounts the other way so clearance is not a problem. I have not run Motons but believe they are just as good, perhaps better. Of course they are about 50 to 60% more money.
Why MOTON is better that PENSKE? Nobody can explain but Moton is better
On bumpy roads my Penske works perfect. The only thing i regret that got 3way - Very difficult to find the right settings...
2way is perfect choice.
Moton is a large supplier to GT3, Belcar, and other European race series which have Corvettes. They take their experience from the track and apply it to their products. They spare no expense with the quality of components used and also provide track support to teams.
The Moton dampers have a monotube design with a much larger piston which displaces more shock fluid. This allows the damper to be far more responsive than a production damper. It responds to the slightest movement of the suspension. There is also nitrogen gas pressurizing the canister keeping the fluid from cavitating and thus making the shock more in control over high speed dampening. The dampers have a blow-off valve system which comes into play over large impacts. This makes it very smooth over hard bumps, makes the car easier to control, and saves wheel bearings and other suspension components. Gas pressure, compression, rebound and ride height settings are all adjustable allowing us to dial in the car for exactly the application we are looking for. While our street settings can also be used on a racetrack, this versatility allows for better suspension control for a special niche of the market that the factory Z06 can't focus on entirely.
You mentioned that they have a blow off system. Do they need to be refilled on nitrogen after each event?
As i know Penske and Motons are very close in performance.But i can be wrong
Former Vendor
Pemske is the direction I went and I am very happy with the results.
I went the Penske direction and worked with Gary Hoffman at Hardbar to get the complete kit. I have been amazed at the performance of the set up he has brought together. There is nothing let to engineer. Everything is adjustable and it fits like a glove. I suggest you discuss what your needs are with him and work out all the logitics as well as installation shops in your area that may have already done an instal of the kit. He doesn't do the installs but he has had alot of experiance with the installation and shops that can handel the instal;l and do all of the correct after installation setups.
Former Vendor
I've had a set of Gary's Penske triple-adjustables on the car since 2007 and they've performed flawlessly.
Something that is not discussed enough with regard to coilovers is the springs.
I gave Gary the spec of wanting a better than stock ride for the road as well as way better than stock handling on the track.
He and his chassis guru Richard Strout came up with a custom dual-spring set up using two Hypercoil springs per corner, one relatively soft to handle the small bumps and keep the wheels on the ground and a stiffer one to control body movement.
When dialled in with the optimum high and low speed bump and rebound settings, I have a Vette that will get me to the track in supreme comfort and one that will easily lap GT3 RSs once I get there!
