[Z06] A host of new body parts available Feb-Apr., 7 new hoods, ZR1 fenders and more
Premium Supporting Vendor
In the next few months, several new and exciting body parts will become available for the C6/Z06/ZR1. These parts are also priced very competitively. Katech will be taking pre-orders on these products now. Credit cards will not be charged until the product ships.
The material is RTM (Resin Transfer Molding)
Resin Transfer Molding is a manufacturing process where a fiberglass continuous mat is placed in a closed female / male tool. Under pressure the mold cavity is filled with liquid resin. An injection machine is used to fill the mold.
The RTM process utilizes large presses and heavy tooling to ensure high quality parts. The proprietary molds are computer temperature controlled for repeatability and part consistency. Average tool weight is 4-5000 lbs
-Parts are same thickness throughout, insure proper stack height and an excellent fit on the vehicle
-Smooth finish on both sides of panel
-Similar mechanical properties to SMC (Sheet Molding Compound)
-Consistent glass/resin ratio content
-Fully cured in mold
-High filler rate for great heat distortion resistance
-Tested for automotive glass A finish
-No air pocket or dry spots
-Tested for durability and show finish, will not distort under extreme heat
Environmentally freindly, low VOC emissions as part is cured in a closed mold
HOODS:
Available February 2009 unless otherwise noted
Initial reports from the manufacturer state that these hoods are lighter than production C6 hoods. Exact numbers will be provided at a later date.
Corvette ZR1-style smooth hood
-No center window
-Will not clear Magnuson superchargers
$1399
Corvette ZR1-style hood with bolt-in polycarbonate window
-Polycarbonate window is removable
-Window may be interchanged with a bolt-in louver set
-$1599
Corvette ZR1-style hood with bolt-in louver set
-Louver set is removable
-Louvers are functional
-Availability April 2009
$1599
Corvette ZR1-style smooth Monster hood
-No center window
-Will clear Magnuson superchargers
-Availability TBD
$1399
Corvette ZR1-style Monster hood with bolt-in polycarbonate window
-Availability TBD
-$1599
Corvette ZR1-style Monster hood with bolt-in louver set
-Availability TBD
-$1599
Katech Street Attack hood
-Design TBA
-Tooling is based off of these ZR1 hoods (similar) so availablity should be this spring if everything goes well.
Bolt-in polycarbonate window
-$399
Functional louver insert
-$299
FENDERS:
ZR1-style fenders
-Availability March 2009
-No emblem hole
-$1699 (pair)
SPLITTER:
ZR1-style front splitter
-Price TBA
ROCKERS:
ZR1-style side rockers
-Availabiltiy March 2009
-Price TBA
SPOILERS:
ZR1-style rear spoiler
-Price TBA
Katech Street Attack spoiler
One of my top priorities upon moving to my position as Director of Aftermarket operations at Katech Performance is to get these body parts going. The highest on my list was the spoiler. I'm happy to say that we have completed the design and it looks amazing. Aggressive, yet classy. We are currently programming and machining a renboard mold plug which will be used to make the carbon fiber mold.
-Availabilty March 2009
-Made from motorsports-quality carbon fiber
-RTM version may be made at a later date
-Competitively priced
Do you have any info regarding weight difference (probably negligible) of these parts vs. a stock part? Namely, the weight of one of these hoods vs. a stock Z06 hood, and the weight of the ZR1 style fenders vs. the carbon fiber Z06 ones.
I am interested to see photos of some of these parts when available.
do you have any info regarding weight difference (probably negligible) of these parts vs. A stock part? Namely, the weight of one of these hoods vs. A stock z06 hood, and the weight of the zr1 style fenders vs. The carbon fiber z06 ones.
initial reports from the manufacturer state that these hoods are lighter than production c6 hoods. Exact numbers will be provided at a later date.
Yes, larger rise to accomodate a Magna-charger.
Thanks. Keep in mind those parts you mention are all carbon, these would be RTM. The front splitter might be carbon. The manufacturer is not sure yet.
Expect pics in the months of the availability dates. I do not have access to the prototypes. If I have pics of prototypes it would be provided by the manufacturer.
I thought you guys were going to come out with your own parts everybodys been waiting for instead of GM knock off parts. Its knock off parts that make the real thing not very unique. I know alot off guys on the forum hold you guys on a high pedastal but these replica ZR1 parts knocks you guys down a knoch in my opinion. How would you guys like if someone came out with imation Katech motors? I'm sure you guys will sell alot of these parts but I sure expected more out of Katech than knock off parts. BTW I like many others have waited many months and held off from buying MTI's splitter, spoiler, and other manufacters splitters, spoilers because you posted several months ago on Katechs behalf that you were working on your own designs. Can't wait to see all the imatation ZR1's running around.
