C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] how to reset the check engine light?
Old 09-12-2008, 10:51 AM
msp282
msp282's Avatar
Default how to reset the check engine light?
i had taken out my fuse for the exhaust and now my check engine light is on. I called onstar and as soon as I heard exhaust gases I told them okay. I put the fuse back in but the light is still on.
i am too dumb to read the manual to see if it says in there...?
thanks
Old 09-12-2008, 11:10 AM
Shootir
Shootir's Avatar
I see you have an 08 Z. Some 08's are having cat failures. Mine did at around 2000 miles. You will have to take it to the dealer to get checked and code cleared. I have my exhaust fuse out also, but that has nothing to do with it. I had them clear the code and waited to see if the CEL came back on or if it was a fluke. Came back on two weeks later. Had right cat changed. So far so good.
Old 09-12-2008, 11:18 AM
Red C6 Z06
Support Corvetteforum!
Red C6 Z06's Avatar
St. Jude Donor '05 '09
thanks
I pulled my NPP fuse and never got a Check Engine light, but then Mine is a '07.
Angi+HerRonFellows (05-19-2023)
CanadaGrant
CanadaGrant's Avatar
On a C6 you need a code scanner with CAN capabilities to reset the light or get the codes. You can get one at any parts store for under a hundred bucks. Since you probably have warranty your dealer is your best bet. You will not get a code by pulling your exhaust fuse.
Old 09-12-2008, 01:38 PM
DJackman
DJackman's Avatar
Unplug the grund terminal for about 10 minutes and that should reset any CEL. Just dont forget to reset both window indexing, set the clock and radio station memory after that.
Old 09-12-2008, 02:05 PM
msp282
msp282's Avatar
thanks for the replies guys! sounds like the dealer is the better choice...especially if i may need a new cat! doh.
I am just over 4k miles... guess that is all a CAT is good for these days.. lol
I just bought that Wild to Mild switch (didn't install it yet).... i think i will wait to install. ahaha
thanks again!
To how to reset the check engine light?
Quick Reply: [Z06] how to reset the check engine light?
