C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] auto rear hatch
Old 04-17-2012, 10:17 PM
  #101
RLSebring
Supporting Vendor
Support Corvetteforum!
RLSebring's Avatar
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Although I sold Bob the parts to do his at the time I have had my parts since then also and been threatening to stop by and spend some time with Bob and do my auto pull down on my Vert while there. Maybe we should steal Bob for half a day soon and take care of both of ours...
Originally Posted by forg0tmypen
I know it's been 6 months but this needs to be stickied. I'm going to attempt to do this soon. I found all the parts I need: mounting bracket, motor, trim, cylinder lock, striker for $100. Also, BEZ06 is only a few hours away if I mess up horribly lol
Old 04-17-2012, 11:05 PM
  #102
forg0tmypen
forg0tmypen's Avatar
You know what that sounds like a good idea. That way it's done right! I might even see about getting the bolsters and lumbar support too lol
Old 12-28-2012, 04:40 PM
  #103
2013gsconvert
Navigator
2013gsconvert's Avatar
I just got the auto pull down latch assembly to try my conversion. I will have to see what is different about the GS convertible compared to the Z06. When I put my spoiler on I did notice a cut green wire behind the outboard tail light. I wonder if that has to do with the auto latch I don't have. I thought it was strange to have a loose wire going no where.
Old 12-28-2012, 06:29 PM
  #104
RLSebring
Supporting Vendor
RLSebring's Avatar
St. Jude Donor '17
You have 2 loose wires back there, Green and Red, that is the radio antenna.
Old 12-29-2012, 09:05 AM
  #105
2013gsconvert
Navigator
Thanks,I was wondering what they did with the antenna
Old 07-05-2021, 08:27 AM
  #106
FelixAC
FelixAC's Avatar
Hello,
I know this post is very old, but very interesting for me.
I already have all th parts but don't have found in this post exactly which wires from the original cables/plug have to be connected to the plug with 6 wires from the auto hatch down. I have only a plug without any cables.
Has someone a list or diaram for this? Or what which wire is in booth plugs? Or where to find?
Thanks to all
Felix
PS I have 2010 convertible, where it would be nice to have ;-)
Old 07-08-2021, 12:29 PM
  #107
dmuellenberg
dmuellenberg's Avatar
Originally Posted by FelixAC
Hello,
Thanks to all
Felix
Yes, this is a very old post and you probably should have started a new thread (according to forum rules). You many also have better luck in the General C6 forum, as this is the Z06 forum and there were no C6 Z06 convertibles - although the wiring is probably still the same for the auto pull down.
Old 07-08-2021, 02:08 PM
  #108
forg0tmypen
there is a “427 convertible” which by all means is a C6 Z06 convertible. Just without the aluminum frame
Old 07-11-2021, 12:40 PM
  #109
dmuellenberg
That is why they call it a 427 convertible - it is not a Z06 because it doesn't have the aluminum frame. A C6 Z06 has to have an aluminum frame.
Old 07-12-2021, 12:14 AM
  #110
AzDave47
AzDave47's Avatar
Received 4,534 Likes on 2,612 Posts
... and be under 3200#s from the factory.
dmuellenberg (07-12-2021)
Quick Reply: [Z06] auto rear hatch
