C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] DRM Bilstein C6 Z06 custom valve shock installation
Old 07-26-2008, 12:31 AM
dvandentop
dvandentop's Avatar
Default DRM Bilstein C6 Z06 custom valve shock installation
sorta a walkthrough installation of shocks on a Z since no one ever post install docs like they used to.
Well installed these tonight wasnt too bad of a job went pretty easy except i didnt have the correct socket to get the rear bottom bolt off (it is a 15/16 btw thx randy)
Waxer warning car is dirty underneath i do actually drive my car
Let me tell you these shocks are night and day difference after getting back from the 15 mile test drive so much smoother over bumps and also when doing cloverleafs on the interstate i didnt feel any bouncing around when going over the seams of the road like i did on the stock ones when taking a cloverleaf at decent speed. I am very pleased with these so far and cant wait to see how the do at teh auto x coming up soon.
Ok so start with the necessary items
upper rear shock mount 2 13mm bolts to remove
Rear 15/16 bolt and nut to remove
the front 2 bolts to take out to remove it, 2 bolts and then nuts are underneath, use a socket on bottom and wrench to hold bolt
upper shock mount on driver and passenger side
note the coolant tank is moved to the side with 2 10mm bolts that need to be removed
had to use a vice grip and rachet wrench since i dont have air tool accessibility
crappy front bushings, not sure if supposed to be torn like that?
hopefully this is worth me sweating my *** off
olde and new shock notice the length diff
had to loosen a arm bolts to remove shock (be careful to not lose the 4 washers on each bolt (do not have to do this on the rears as they slide out pretty nicely.
tightening up the front bolt
removing the rear top mount for shock
Almost done
Mission accomplished!!
Old 07-26-2008, 12:51 AM
427Z
427Z's Avatar
excellent somehow, i was expecting the guy in your avatar to be turning the wrenches
you've read my experience, now its your turn. let us know how you like them.
Old 07-26-2008, 01:21 AM
allanlaw
allanlaw's Avatar
I know, where was I earlier, but Pfadt's website (under "documents") has very good step-by-step instructions for swapping shocks. They (and I) strongly recommend dropping the top a-arms to make removal of the old shocks a lot easier. Also, a little jack raising up the lower arms at certain points in the install can make it a little easier to do.
Good work in cramped quarters - my hat's off to you.
Old 07-26-2008, 01:32 AM
dvandentop
dvandentop's Avatar
hand tools like usual no luck on air compressor since garage doesnt have lights either so finished just in time to torque down the wheels to be able to hit a test drive tonight.
yep had to use a jack on lower A arms to get some of the bolt holes lined up also
Old 07-26-2008, 02:11 AM
427Z0SX
427Z0SX's Avatar
Excellent writeup! Thanks a lot. Where did you get all the torque values for final tightening? Are they included in instructions with the shocks?
Old 07-26-2008, 10:19 AM
dvandentop
dvandentop's Avatar
to be honest i didnt use a torque wrench and never do use one i have done many projects over the years and only use one for engine related or transmision related stuff. never had any issues at all
but i think david farmer racing website has all the torque specs on it
i am an old farm boy so pretty much tighten it until you cant crank it down anymore. but you can feel on which bolts cant be cranked down really hard due to they are softer bolts and could turn off if you crank on them too much.
Let the flames begin from all the perfectionist who will bitch around but the dont even do their own work anyways
Old 07-26-2008, 10:30 AM
zhopper05
Support Corvetteforum!
zhopper05's Avatar
2015 C7 of Year Finalist
Good work man - waiting for the verdict after the test drive.
Old 07-26-2008, 10:40 AM
dvandentop
dvandentop's Avatar
i did post a review of initial test drive in 2nd paragraph up top in 1st post.
Old 07-26-2008, 10:42 AM
zhopper05
zhopper05's Avatar
My bad -I started reading from the bottle down.
thanks
Old 07-26-2008, 12:35 PM
allanlaw
allanlaw's Avatar
The shops do this job using air tools to tighten all the bolts - not a torque wrench in sight.
Old 07-26-2008, 12:57 PM
ken-rx
ken-rx's Avatar
Nice to know I'm not the only guy to turn a wrench. Nice write-up.
Old 07-26-2008, 01:13 PM
patch68
patch68's Avatar
Nice write up. I put bilstein sport shocks on my C5 after I lowered it, and they were night and day difference over factory ones.
Old 07-26-2008, 03:03 PM
tigertank
tigertank's Avatar
dude ur not ur avatar!!!!!!!
Old 07-26-2008, 03:56 PM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
__________________
Contact:
(e) zach@katechengines.com
Old 07-26-2008, 04:58 PM
outnumbered
outnumbered's Avatar
Originally Posted by Katech
Old 07-26-2008, 05:06 PM
dvandentop
dvandentop's Avatar
hahaha great jason!
i should edit my post to show that instead of regular pic to really mess with people haha
Old 07-26-2008, 06:23 PM
427Z0SX
427Z0SX's Avatar
hahaha great jason!
Now how do we know it's not the other way around?
To DRM Bilstein C6 Z06 custom valve shock installation
Old 07-26-2008, 06:33 PM
427Z
427Z's Avatar
Old 07-26-2008, 11:09 PM
C5 Frank
C5 Frank's Avatar
Jason thats too funny!!!
dvandentop... Nice job!!!
Old 07-26-2008, 11:24 PM
blackvetterzo6
blackvetterzo6's Avatar
Received 1,019 Likes on 567 Posts
Gotta tell ya Derek you dont screw around. All you need is a good lift and a air compressor and your set.Anyway i dig the hands on rip it up program.Good job.
Quick Reply: [Z06] DRM Bilstein C6 Z06 custom valve shock installation
