[Z06] Road&Track Nissan GT-R vs. Chevrolet Corvette Z06 vs. Porsche 911 Turbo
#344
#345
i hope you don't have a math background; if so you might want to refresh.
HP is a unit of work and is dependent on engine RPM. AUC is not dependent on RPM. For a flat torque curve, the "instantaneous" AUC at 1000 RPM is the same as at 2k RPM is the same as at 3k RPM, etc., while the HP at each of those points is of course different.
http://www.jimrobinsongroup.com/car_...duramax.b.html
In the RPM range from idle to redline, 90% of its' torque is available over 71% of its' entire RPM range. You can look at the curve in the power band and see it's about as flat as a table top like most other diesels...I get the feeling you don't have much experience with diesels.
also, as you pointed out by talking about gearing, wheel torque is what really matters. an engine with a broader, flatter, higher AUC but lower peak torque curve can be in the powerband longer than an engine with a narrower, spikier, lower AUC but higher peak torque curve. for the same car, even if the flatter engine is low on torque (ie, below what the tires can handle), we can make up for it (relative to the other engine) with shorter gearing and the "damage" to the width of the powerband will still be better than what the other engine can offer. it should be apparent that the higher AUC engine in this example is better. it doesn't matter where peak torque occurs (ie, HP doesn't matter) except to establish the width of the powerband.
i know i am rambling on, so i'll quit now and anyway we are way off topic. i'll review the other thread you pointed out and start off a new thread if i disagree with the findings there. (someday)
http://www.roadandtrack.com/assets/d...6911_chart.pdf
The Z06 is 3.4 sec to 60 and 10.7 sec to 120 while the GTR is 3.4 sec to 60 and 12.7 sec to 120. By the KE formula and using the 0-60 times, the Z06 and the GTR should have gotten to 120 in 13.6 sec. The GTR has enough grip off the line and very steep gearing for 1st gear to maximize HP at the beginning but it's hurt by the large drop in RPM on the 1st-2nd shift and it gets close to its' predicted time based on the formula. The Z06 is nowhere close to the predicted time indicating it doesn't have the traction off the line and it's hurt by gearing not letting it get up on the HP curve until about 40 MPH. Working backwards, the Z06 has the potential to do a sub 3 sec 0-60 run (10.7/4=2.675) if geared properly and with enough traction.
Ok, now I've rambled on. But I do invite you to review the other thread I linked to...and please let us know if you disagree with any of the people I listed.
#346
Well, your first sentence is half right. Torque is a force that may or may not move/accelerate (I'll assume you meant accelerate) the car. You can have torque without movement so torque only tells half the story. Horsepower will not only move/accelerate the car, but it'll tell you the "rate" at which a car will travel a given distance...as in ET for a 1/4 mile. It'll also tell you the speed of the car (kinetic energy added) at the end of the 1/4 mile. Look at all the 1/4 mile ET and MPH calculators...the only two variables in the equations are the weight of the car and the HP of the engine. Nowhere in the equation is torque used.
You get half credit for the 1st sentence and none for the second for a score of 25 on this test...sorry, you flunked. Study some more and better luck next time.
I pass, you fail. I thought you were smart. Guess not.
Again, torque is the force that moves the car. Horsepower is not a force, it is only a calculated value that the REAL force (in this case torque) performed.
#347
and the Datsun V spec just ran a possible 7:25 on Nürburgring... now we just need a lap time from ZR1
maybe you call it a Datsun.. but it's beating just about all the other car makes out there. consider calling it Nissan and it might just ease up the pain a little.
Bugatti Veyron is the fastest cars by acceleration
http://en.wikipedia.org/wiki/List_of...y_acceleration
but it's not the fastest in the ring
http://en.wikipedia.org/wiki/Nordsch...test_lap_times
can't wait to see corvette going heads on with GT-R is GT races..
#349
I was NOT wrong. Turn in your degrees, your ignorance just out horsepowered your intelligence. Torque is the force that moves the car. Horsepower is not a force, it is a calculation of work. Horsepower does not "move a car" it is merely a calculation in an attempt to determine the amount of work done over time.
You now have mechanical engineers, electrical engineers, physicists, and mathematicians lined up against you. Are there any chemical engineers available to chime in?
#350
HP is not a calculation of work, it is a measure of the rate at which work is being accomplished...work and HP are two completely different concepts. Yes, HP can be calculated but it can also be measured...how do you think an inertia type chassis dyno works? It takes a roller with a known moment of inertia and measures small increases in RPM of the roller to come up with the amount of kinetic energy added then divides that by the small interval of time in which the kinetic energy was added times a constant to get units of HP. From there, the RPM probe picks up the RPM at which the HP was measured and calculates torque.
HP is not just a calculated number, it is as real as torque or feet or pounds. For a demonstration, 1 HP=~750 Watts...go grab a 75 watt light bulb (about 1/10 HP) and let me know how real HP is. Not only does HP move a car, it determines the rate at which the car will move.
Also, "the amount of work done over time" is energy, not HP...once again, HP is the rate at which work is done. Look at the units in the HP formula when you multiply torque and RPM...LB-FT*rev/min or LB-FT/60 sec. Now look at the definition of HP...James Watt determined (somewhat arbitrarily) that the average horse could lift 550 pounds one foot per second or 550 LB-FT/sec. Just for your info, the pound and foot are arbitrary measures too.
You failed miserably this time...you're way out of your league with this stuff, but nice try.
#351
An electric motor makes its' maximum torque at locked rotor (zero RPM), but since nothing is moving, it is doing no work and produces zero HP since the equation HP=torque*RPM/5252 has zero for RPM in the numerator. You can make all the torque you want, but if you don't move anything, it means nothing...once again, HP has the time factor in it which indicates work is being accomplished. But yes, torque is the force that accelerates the car when a sufficient amount is applied to get it moving.
#352
The ring time was that not with a flying start, 100 ft. lead off the line when the timer started and 400-500 ft from the finish line when the timer was started?
There was a post on here with actual pictures. Let's wait and see what a stock production one does with a line to line stop/finish and a standing start.
#353
Ok, I can have two dyno graphs from completely different engines where the AUC for torque in the engines' powerbands are equal and peak torques are equal, but one engine makes twice the HP.
My POINT was that if engine #1 has 20% more area under the torque curve compared to engine #1, then the hp curve will also have 20% more area under the curve compared with engine #2. The plots of Q vs rpm and hp vs rpm provide the same information about the engine's output characteristics, so it doesn't matter whether one compares the Q curves or hp curves, becasue knowing one means knowing the other (no EXTRA information is conveyed by looking at one vs the other).
And in the quote above, at face value this doesn't SEEM to be correct, since equal Q areas means equal hp areas (unless there is more to the description than is written).
#354
Not now...............
Post ANY GT-R related stuff here...........sticky thread at the top of this forum
http://forums.corvetteforum.com/show....php?t=1988356
