[Z06] to add or not to add... Octane booster?
Hello all, I am excited to be here as my dream came true and I got my very own 2008 ZO6 (masterfully crafted by the one and only Robert Vernier). I have a couple questions about it already, My work brought me to California where the best you can do on octane is 91. It seems like after I ride the beast hard even for a short distance I notice a little knocking or ticking noise. If I add octane booster will it help this? Thanks in advance for any help.
The majority of members here think that octane boosters are a waste of money. You can try searching the forum and probably find the old thread. I have never used them because I get the 93 octane.
The 91 octane should not be a problem. The car's computer should compensate for the lower octane. These cars seem to make alot of unusual noises that are specific to the LS7 engine and easy to explain. I would suggest posting a very specific record of your car's symptoms and someone will surely help you out.
My car had a ticking on acceleration, like pinging, that disappeared after lowering my car about an inch. Go figure. Anyway, I would have sworn that the noise was engine related until I talked to the corvette tech where I bought the car. He said it was probably something rubbing under the hood. I guess I got lucky.
The point is, you can be fooled by these noises and I wouldn't bet that your car is ticking or knocking from low octane gas. Probably just the normal valvetrain tick. The LS7 is noisier than the average V8. Good luck.
I would be careful with Octane booster. Most all of it is usless. Many in the Forced Induction section have done well with Torco (C5 section). I too live in California and if I am planning to tack the car I will toss in a gallon or two of Xylne. It's another option. You can buy it at paint shops and Home Depot as well. It's 117 octane but very dry. Wouldn't go crazy with the stuff. Hope that helps.
Thanks, I do assume its the normal ticking of a push rod engine, its a muted tick and not alarming when i hear it. I figured I would still throw it out there though.
I do the same thing and it works very well. The MS 109 is a unleaded racing gas rated at 101 octane for aspirated engines like the LS7.
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,107 Likes
octane booster = snake oil
And congrats on the 08 and sorry you had to move to CA
i doubt that what you are hearing is detonation....just normal valve train noises....i can only get 91 here in tucson...have been logging and tuning my car and never have an issue with 91....
would not waste my money on octane boosters...
Most engines are simply not capable of using high octane gas.
Will I get extra performance if I put in 93 into my Honda accord? No. That doesn't mean 93 is the same as 87 and we're being ripped off.
Boosting 87 to 93 for the LS7 makes sense but boosting 93 to 97 will probably not add any power with an engine calibrated to run on 90-93. It'll just make your safety net bigger.
More is not better, less is worse.
The noise you're talking about is probably because of the heat-related expansion of the various materials at different temperatures. I dont know exactly what causes it but its normal.
One thing to be aware of with those little jugs of octane booster is that, while they may be making a valid claim to raise your octane by say 2 "points", that only translates to 0.2 of your octane rating. So rather than taking you from 91 to 93 as many people read this octane boost as, you are really only taking it from 91.0 to 91.2 rating. Also, you have to look at how many gallons one of those little bottles treats, in many cases that doesn't apply to a quantity as large as a full tank of fuel. That translates to very expensive fuel.
As others have recommended, just pick up some *unleaded* (unless you wanna pooch the platinum in your cats!!!) race fuel, I use 104 as my octane booster, as I generally have a barrel of it around for the bubbacar (stock car). If you don't think you will use a whole barrel of it within a season, you should be able to find it at a pump at just about any race track.
imp.
imp.
It may not be the cheapest route though. You can buy a gallon of the stuff for as high as $15 at Home Depot and as low as $9 or so a gallon with an account at a paint store. A ratio of 1:16 should get you to about 92.5 (92.625 actually). Pretty expensive and inconvenient way to go assuming the Torco works as some say it does. A small can of Torco is pretty conveneint.
Finished an 8000 mile cross country trip and used gas from 89 to 94 and there was no noticable change in performance. The only thing that I noticed was the LS7 dosen't like altitude, acts like a de-nutted duck at 6000 ft. Tried some of the Torco in my 02 convertible, 1 quart to 18 gallons drove 150 miles and lost 18 rwhp at a dyno event in Gardina CA. (336 down to 318 rwhp)
