[Z06] rear end noise
rear end noise
I've read a lot of posts about the clutch plates noise and possible soloutions. T he one that seemed to work the best was the one about AMSOIL additive,so I went looking for it, tuff to find a dealer around here but finally found one. I was talking with the owner of the store (sells bikes and snowmobiles) and apparently they use a lot of the products. Well ,he says that the noise could be from air being trapped in the differential ,he says that the additive takes the air out and after awhile it does comes back . Not being an engineer or a mechanic is this a sound theory ? (please i am only a messenger)
Cruise-In VIII Veteran
St. Jude Donor '06
I don't know about the air in the system and I intend to switch over to some type of synthetic lube for the rear end.
Also there is a TSB on the rear end noise, I would take it to the dealer and let them change the flluid under warranty for two reasons.
One its free and the other is that now there is a record of the noise if there is a problem with the rear end later.
I had the dealer change mine at about 13K and at 17K the noise is starting up again.
posi chatter/noise has been around as long as posi's have...the gm fluid is synthetic...every now and then find a deserted parking lot and do some figure 8's....this helps get the lube in between the posi clutch plates and reduces chatter/noise
Premium Supporting Vendor
The friction modifier changes the fluids coeficient of friction to prevent the clutch plates from chattering as they rub against each other when the wheels are rotating at different speeds. You can read a little about it on this link:
AMSOIL Slip-Lock Differential Additive
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
I had mine to the dealer a couple of weeks ago for a four wheel alignment. I mentioned to the service writer that they changed the diff fluid and added the friction modifier back in November because of the clunking noise. It got better but still makes some noise. He said that GM now has yet another lube to address the problem. So, they changed the fluid again with the new stuff. It works very well so far.
GM's Dexron LS cures the rearend chatter at slow speeds. Had it put in my 07.
Its also in my 09, (factory fill) and thank god its quiet.
