[Z06] SAVE YOUR MONEY...K and N WORKS!!!!!
#141
I'm going back to lurker mode now. Look forward to the test results at K&N.
Regards,
Jim
#144
ok? what exactly are u sayin that those prices are wrong? either way aren't u in socal? why don't u take ur kb to be tested with the k&n unit that way we will all be informed and full of facts... also can u tell me what the prices are on those intakes since I got em wrong? thanks.
R.
R.
#145
St. Jude Donor '08-'09
I did tighten the clamps good and tight. Just wonder why it was ok when I placed the unit on the car.
I believe it was a combination of tight clamps and heat that caused it.
augydog
#146
You're exactly right, it was a combination of heat and overly tightened clamps. I didn't mention the heat, but that was implied. Sorry for the omission.
#147
#148
ok? what exactly are u sayin that those prices are wrong? either aren't u in socal? why don't u take ur kb to be tested with the k&n unit that way we will all be informed and full of facts... also can u tell me what the prices are on those intakes since I got em wrong? thanks.
R.
R.
Try clicking on the supporting vendor list along the web page, Vararam's from 329 to 430, Vortex 249 what can I say. They will have some for 600 also. The statement was used to typify a point not to start another ebay. The point of that dissertation was the word imply nothing more.
#149
R.
#150
Katech already did the test and it's posted on this forum and they came out nearly the same with the K & N having a 1hp blip over the Halltech at peak. If you analyze the area of the curve you will see that the Halltech may have had a slight edge overall. For all concerned they were the same on a dyno curve. Now when you add support and mechanical issues the Halltech is a slam-dunk.
#151
Nope - I'm still stock (which is good because it eliminates the porting, tune, etc. variables). I'd need to borrow one. Any donors?
BTW - this is a decision I'm still on the fence about (KB v K&N).
#152
#153
I think for any test to be fair, an independent tuner should do it. Oh wait Katech already has done it...............but in any case it should be a neutral person.
#154
I'm looking into aqcuiring an aftermarket intake for an LS3. So I thought I'd ask here.
Can someone describe why these intake units/filters make more horsepower than stock? I don't think the stock has any "bottlenecks"(I may be wrong). So, I'm wondering what is it that K/N, or Halltech know that GM doesn't. I'm also wondering how the aftermarket filters compare in terms of actual filtration vs stock unit.
#155
A lot of people like drama....you know that!
If you think everything should be based on "implication", then you're gonna have issues in life.
I'm sure there are other intake systems around $500.
I think Jim causes half of his own drama sometimes ... along with the help of the other drama queens. Fact, is the poster never mentioned any company or names … it was all “implied” by the drama queens.
#156
Yes again but they did not test the filtration of each unit thats where the K&N tests will differ... and again these units werent the ISO units that me and you get these units were pre release units. I can see why u wouldnt volunteer for it same reason why all these others with KBs wont. But im not gonna start the drama since im not a drama queen lol but im sure alot of us like Puto(yes i called u that) would like to know the real deal behind every aspect not just how perty it looks....
R.
#158
#159
#160
R.
R.
Volunteer for what, if you mean drive up to some tuner and do a side by side, no problem bring it on. Why are you all hung up on this volunteer thing?
