[Z06] RPM limit?
RPM limit?
This dyno graph shows them running the motor to 8000rpm with some power drop.
http://www.gmperformanceparts.com/En...2397&engCat=ls
Does this mean the motor is good up to 8k rpm?
They may have simply extended out the trend lines. Either way, I would NOT run mine past 6500. As with all LS7 (stock) charts I've seen, HP begins to fall off after 6,250 or so. Why would you want to run much past that anyway???
In order to get the best possible times from any car at the drag strip, you have to pay attention to the "area under the curve" and try to maximize the HP applied throughout the run. In order to do this, you will have to go beyond the HP peak.
BTW - The Rev-limiter on the LS7 is set to 7100 RPM.
Can't aruge with that, but...I spend my time on a road course and not a drag strip, so techniques are different.
Does anyone know the actual RPM drop between gear through 4th??? Also, why don;t any of the dyno charts I see posted here show the shift points and associated "blips" in the graph? Do the new reports "smooth" them out??? The old dyno I ran on many years ago showed this, and it was helpful to see the time intervals during shifts to give you an idea on your shift speed or your autos efficiency.
Received 3,836 Likes
"Ask Tadge" Producer
jas
you can do that, tomato, but I assure you, at least for a straight line, you will go slower than someone getting right to the edge of the limiter. maybe for a road course guy like yourself, no big deal. it pulls awesome even to 6500
Optimally, you'd pick your shift point so that your HP at the point you shifted was about the same as what it would be when you entered the next gear.
On a (stock) C6Z, even making your shifts at redline will still produce more HP than when entering the next gear at approximately 5,000 RPM.
Take a look at the HP profile from a dyno of C6Z to get a better picture of how this works.
Not really, the techniques are the same. If you look at running from one corner to the next or going down the straight as drag races, the same techniques apply. If you shift at 6500 RPM and I'm in the car next to you going to 7000 rpm, you just left HP on the table and I just left you behind. Quickest lap times will result when shifting at red line with few exceptions.
Let's assume a proficient driver makes two acceleration runs, 0-130, identically driven except for shift-points.
One run he shifts at 6500 and the other at 7000.
Now, the 6500 run will be slower by about 4-5 tenths of a second. That's about five car length, a considerable margin.
If you think about some of the videos you've seen where the difference between two racers is a couple car-lengths, giving up five car-lengths due to short shifting is pretty much driver error.
Your dyno operator can print the results (or give you a file) in the form of a spead sheet with rwhp and rwtq in plain values at 100 rpm intervals. If you study those tabular data, you'll find that the rwhp value between 6500 and 7000 is higher than it is between (post-shift) 4700-5200. That was the point dgdoc made in post #11.
Ranger
I'm wasn't telling you how to drive your car as that's a personal matter and I'm not the one paying for it.
Read the last paragraph of Ranger's post above, that is the best explanation here. And again, it's your car, enjoy it how you want to as that's all that really matters.
PS I haven't met a car yet I couldn't drive past its' limits. Not that I'm that good, I'm just that stupid!
Ok, here's your first lesson...shift at 7000 RPM. However, this lesson will be wasted on you as you've already stated emphatically you won't do it.
You asked why go past 6500 RPM, I simply gave you an answer.
Just to clarify, I did not emphatically state that I would not do it. Actually, I shift closer to 7 on the street. Road course I aim for 6500-7000.
Again, thanks for the tips.
Well, let me add another 2 cents. The guys that run flat out on a road course all the time will be the fastest. If you are a half a lap ahead sometines finishing is more important than being the fastest. However, since braking is involved shifting at 7,100 RPM and then immediately downshifting and braking may not always be the fastest. Speed coming out of a corner is all important in road racing. If you watch video from inside the car you will see guys seting up for corners to maximize out of corner speed not minimizing time to and into the corner. You can give up time into some corners so that your exit is better and be faster. The overall objective is to be the fastest into and out of each corner and the fastest down each straight away.
I'll steal a quote from another member...Let's stop "bench" racing and get out to the track!
