[Z06] How To: build a quieter C6Z
The following is a step-by-step chronicle of my soundproofing work on my '06 Z06. The stock Z is fairly quiet, except for gear rattle at low RPMs and loud tire noise over concrete. Add a set of headers, however, and with the windows up the interior is dominated with header tick and engine noise at idle, and bass drone from the (stock) mufflers at cruising RPM and acceleration. This makes the car significantly less pleasant to drive for >15 minutes, and calls for a solution. My first attempt at having both power AND quiet is described below, and the procedure as well as the results will be provided.
For soundproofing, I will be using a combination of materials from B-Quiet. I'll have a complete list of what was needed once the project is complete in 1-2 weeks. My initial order was:
2x B-Quiet Ultimate (50 sq. ft.)
1x B-Quiet Roller
1x B-Quiet Hliner (13.5 sq. ft.)
3x B-Quiet Lcomp (8 sq. ft.)
I expect I'll have some leftovers when complete.
In addition to the soundproofing materials, you will need the following:
Socket driver
7mm socket
10mm deep socket
16mm or 5/8" socket
Notch-head screwdriver
Torx T30 socket
1x B-Quiet Roller
Socket driver
7mm socket
10mm deep socket
16mm or 5/8" socket
Torx T30 socket
Step 1: strip the trunk
Remove fasteners at points (1) and (2), and then pull on the trunk liner until the fasteners at point (3) pop out. Pull the liner out slightly, and disconnect the wire connectors to the lights next to (1) and (2). Remove the liner and lights and start a pile -- there's more coming.
Step 2: remove the seats
Move the driver's seat backwards to expose the front attachment points. Remove the fasteners holding the 2 plastic bolt covers in place, then slide the covers forward and remove to expose the bolts illustrated. Do not pull UP on the bolt covers, as this will snap their delicate internals (don't ask me how I know).
Remove the two front seat bolts using a 16mm or 5/8" socket (an electric impact gun is recommended for the extremely lazy )
Step 3: continue removing the seats
Now, roll the driver's side seat forward until you can easily access the rear bolts. Before unbolting them, disconnect the battery, since you will next be detaching the seat-mounted airbags and it would be a real shame if they went off in your face
Once the positive lead is disconnected, remove the rear seat bolts using the same 5/8" socket.
Remove the two front seat bolts using a 5/8" socket (an electric impact gun is recommended for the extremely lazy )
Step 5: unplug and remove the seat
With the battery disconnected, tilt the seat sideways toward the interior of the car and unplug the three separate power plugs under the seat -- (1) and (2) for power seats, (3) for the airbags.
Finally, detach the seat belt mount point from the seat using (you guessed it) your 5/8" socket. Carefully remove the seat (don't scratch anything with the seat rails - they're sharp) and set it aside.
Step 6: remove the passenger seat.
The procedure is the same as for the driver's side seat, except that you will not need power to move the seat back and forth. Note that there is one electrical plug on the seatbelt mount point which is not present on the driver's side seat.
Step 7: remove the rear center console, pt 1
The center console covers a significant swath of thin, sound-passing sheetmetal. Off it comes!
Start by opening the center bin and removing the two rear bolt covers using a screwdriver. The bolts are 10mm. Remove them and set them aside, but do not yet try to remove the console.
Step 8: removing the center console, pt 2
1. Remove the small silver cover just behind the shifter
2. Carefully unclip the e-brake boot as shown and lift it clear
3. Undo the three forward bolts as illustrated.
4. Carefully lift and slide the center console backward. A part of the front console on the passenger side will come along for the ride - be sure not to torque it as you remove the console.
5. Finally, remove the thin rubber matting between the two rear bolt studs.
Step 9: unbolt the seat emergency releases
Remove the bolt covers on both seat releases.
Next, use the Torx T30 (you DID get one, right) to unscrew the bolts holding the two releases in place. Set the bolts and bolt covers aside, and pull the seat releases out of the way.
Step 10: remove the accelerator backstop and dead pedal
Using a 10mm deep socket, remove the two nuts that hold the accelerator backstop and the two bolts which hold the dead pedal in place. Remove both plastic pieces and associated nuts.
Step 11: ready to start soundproofing!
Remove the driver and passenger side interior carpeting and the rear carpeting. Try tapping on the sheetmetal on the firewall, tranny tunnel, the trunk bedliner, and the area just behind the seats. You'll understand why there is such an opportunity to improve the soundproofing on this awesome vehicle!
That's all for today - the above took me 3 hours working carefully, and would probably take 2 hours for a pro. Next, I'll document my soundproofing work and the results -- ETA, about a week.
most helpful
For us die-hard performance at all cost enthusiasts, do you think you could get an estimate on the weight of the materials used? It would be nice to see what the trade off/weight savings are. I can't imagine it would be much weight.
Corey
Corey
