[Z06] How is the paint on your new Z06?
May I respectfully ask how satisfied you are with the paint on your New Z06?
I seem to recall great pains and strides were taken to perfect the paint process on Corvettes...
How does yours look up close?
Thank you.
Thank you.
I was a little disappointed to see a lot of orange peel on a black Z06 I saw the other day. I know that Vipers are polished at the factory to remove the orange peel. Why don't they do that for the Z06?
Sorny
Location: Do you know what they call a Quarter Pounder with cheese in Paris?
Cruise-In VII Veteran
St. Jude Donor '06
I have a Viper and was just comparing the paint.
What about the clear coat?
Originally Posted by gonzalezfj
Orange peel is most noticeable in the darker colors. If it bothers you so much, your local paint shop can wet sand the affected areas with 2000 or 3000 grit paper, then polish it again. Orange peel will be gone.
I wonder, when they wet sand a car like that do they remove the clear coat?
I'm hoping my new Black Z06 with the factory clear coat will be easier to keep clean than a full detail after every drive.
Originally Posted by BlkC6Z06
I did that on my Black NSX, and although when it was clean and detailed it looked amazing, it only stayed that way for a few days then it showed every bit of dirt because of the "mirror" finish...Even more so than other cars with the factory black finish that seemed to wipe clean with little effort.
Ths dirt just shows more on a darker color car, with black being the absolute worst. I had a black car once and swore, never again. You could see dust on that sucker 1 hour after washing it.
Originally Posted by Z06Vettefan
What the heck in orange peel on the paint? Does someone have a picture of what this looks like?
Yeah.
Good = ________________
Orange peel = --^--^--^--^--^
(All graphics (tm) Crazy ASCII Indistries Inc.)
look at the texture of an orange. If your paint looks like that, it is orange peel. The wose I have ever seen was on a black Dodge Durango this year, so its not only GM.
It's not just American cars. My Elise has orange peel, as do (seemingly) every Elise I've seen. Of course on the Elise we're just happy if they actually put a full coat of paint ON THEM. Some have reported seeing the base fiberglass in spots. I'm fortunate, got a decent paint job from the factory.
Orange peel happens when a surface is painted that is not perfectly smooth (and im talking about smoother than you can feel). To get rid of it as others have mentioned on this thread, the area must be wet-sanded and re-polished.
Wet-sanding can happen at a few places: 1. either at the paint base layer (at which time after wet-sanding, there would be another coat sprayed on, and wet-sanded again until there is no abrasion when sanding..then a final clear would be applied) or 2. at the clear coat layer. Unfortunately, if the base coat isnt smooth enough, and the clear is shot on, there is the possibility that when you wet-sand the clear, you will have "valleys" of clear to sort of fill in the base dimples and very thin layers of clear.
Cars that are produced for the mass-market (even the Z06 is for the mass market) are all going to have varying levels of orange peel.
