Am I the only one having a LOT of problem with the FOBs???
Man,
I sure would like to go back to a key. The new FOB forces the memory seat/steering wheel feature to be more tedious, and now - as often as not - the car doesn't seem to "see" my FOB.
I end up having to dig it out of my pocket and press the unlock button to get in the car and when I turn the car off it says "No FOB detected" and asks what I want to do. I have to wave the FOB around like a moron in the car while repeatedly depressing the off button.
I also noticed that the C6 Z06 dashboard, had the "Please put shifter in Reverse" message on the DIC. Even GM hasn't got it figured out!!!
Push button start is a gimmick that has actually greatly complicated entry, exit and starting/stopping the vehicle.
I wish it had been an option. I'd have a key and saved some money.
Tom, several people have reported problems with the FOB, but at least part of the time, an explanation was found. Sometimes it's multiple FOBS (for different vehicles) in the same pocket, at other times it's a cell phone nearby. There might be something wrong with the sensor in your car.
Although I wear a cell phone at my left waist & keep my FOB in my right pocket, I've only had a FOB problem one time.
EDIT: Since you have a 6-spd, you have to press the memory button to set your seat, etc. for driving position, but I got used to that in my 6-spd. I also had it programmed to unlock the doors at engine shutoff, so all I had to do after I put it in reverse was to open the door. Of course, if your FOB's presence is not recognized, you've got a problem!
I couldn't agree with you more.
Luckily it's generally just a minor nuisance. After a few months with the car, the problems seem less apparent, and occur less often.
Remember that cell phones and other transmitting keys might interfere with your fob.
Also, try the other fob. Maybe yours is loco, or low on juice.
Didn't look at your sig, do you have an auto or manual tranny?
It is frustrating and a little embarassing to spend that much time trying to get out of your car!
Man, this whole "keyless" thing seems like a neat idea, but hearing these problems makes me wonder.....we've been using KEYS to get into our cars and start them for years and years.....I dunno, if it ain't broke, don't fix it, right?
These problems are just growing pains and getting thousands of people used to new technology. A lot of the new owners tried to use the new technology without reading the manual. A small part of it was GM not giving us adequate warning about nearby cell phones & other FOBS.
Once you get used to it, it's no big deal.
You are all kidding right? Just sounds like a dead or dying battery in the FOB-or the FOB has to be re-learned by the car if the battery was taken out of the FOB(this is a ROLLING CODE system-just like the New Genie Door Openers.) The message "Please put shifter in Reverse" is "seen" in the DIC by all manual shift C6's when you turn off the engine in any gear other than reverse and that is to "turn off" the electrical system(whatever that is supposed to mean, but that's what the manual states.) But what the hell, cars haven't been the same since they got rid of steam engines dagnabit! Keys, Please!
No, you don't get improvements that way. It is an improvement for me not to have to search for and dig out my keys when I've got something in my hands while going to or from the vette.
Change for the sake of change, isn't necessarlly an improvement. That's why "20-20 hindsight" was invented, so we can undo the "improvements".
Two fobs in the same pocket does cause the "no fob..." message in my MN6.
The keyless thing is a pain until you get used to it, then it is kinda' cool. I do miss the memory recall when the key went into the ignition, but I like not fumbling with the fob or keys when opening the door.
So.... win a couple, lose a couple...
Originally Posted by H101
I do miss the memory recall when the key went into the ignition, but I like not fumbling with the fob or keys when opening the door. So.... win a couple, lose a couple...
Originally Posted by Hoonose
It would be nice if the memory seat would close up automatically after you close the door, without having to turn to hit the memory recall button.
It will if you have the auto tranny and you start the car. Sometimes I get in the car to get something out of it or look at the owner's manual. I don't want my seat to move until I start the car (I've got the auto. tranny).
Why not make it an option then?
But I understand what you're saying. You'd like to have the option to automatically move when you open the door. However, that would nullify your easy entry position.
Since Im tall and have the seat all the way back the easy entry doesnt really gain me anything so I set that to be the same as my memory 1 so that after my wife drives the car everything is right where its supposed to be. If your shorter and you can gain some advantage with the easy entry feature then this wont be for you. My key fob BTW has worked fine. I leave it in my pocket at all times. I walk up to the car and get in and push the button to start. When I exit I push the button again and get out. It locks itself and honks the horn to give me locking verifaction as I walk away. Seamless. The only thing I had to learn was that I used to leave my car in first or reverse, whichever one I used as I parked. Took a few days to get used to reverse only.
so far, I love it and have had no problems with it.
only once did it do something wierd... kept beeping at me telling me that I was shutting the car with the fob still inside... couldn't figure out why.
then realized that my 2nd fob was in my laptop bag.. in the car.
duh.
duh.
I have 5 cars and trucks here. For 4 of them I have ONE key ring, with 4 car keys and one house key. That's worked flawlessly for years. Now I also have to have a FOB, the emergency key, and a house key on a separate ring. I shudder to think what it would be like if all the cars had FOBs. I don't think I have enough pockets for that, and for damn sure sooner or later I'll have the wrong set with me when I'm in a hurry. That's why I had them all on the same ring in the first place.
The keyless entry system is convenient when it works, but IMHO the keyless start is pure gimmick. Even when it works, you wonder if it would also work for someone else (ie a car thief). And heaven help you if several years down the road it fails. The electronic parts to repair one will be obsolete, you won't be able to get them, and your car becomes an expensive lawn ornament.
Keys may be low tech, but any semi-trained hardware store clerk can make you a new one, or rekey a cylinder, even for an old car. They don't care about cell phones, they don't care about garage door remotes, they don't care about palm pilots or ipods, keys just work. They're compact enough you can carry several on the same ring, and they won't break if you drop them, run them through the washer, etc.
I don't like the bulk of the fob. I don't like the susceptability to interference of the fob. I don't like the fragility of the fob. Etc. Keys are better technology, even if they aren't "new". New isn't always better. Foolproof is better. Reliability and robustness are better. Simple is almost always better. Keys are simple, reliable, and robust. They are darn near foolproof. Nearly everyone can figure out how to operate a key without consulting a manual.
Agreed, as transportation you want it to work everytime. As a toy, bring on the goodies! Everybody who opens the door for the first time or watches me start the car by pushing the button is awed. It's bling!
The STS we just ordered will have the same push-button start setup as the C6, with the same style FOBS. Except the STS also has a "remote start" button on the FOB to start the car and recall a unique "remote start" memory profile for the A/C and heated/cooled seats from up to 200' away.
Stephen
Keys might be simple but they work well, don't break (under most conditions) and everyone knows how to use them.
Fancy FOBs & keyless starting might be the latest/greatest but I don't think it will last the test of time. It will eventually just become another expensive thing to fix.
