Other Synthetics Vs Mobil 1
My car has 1,200 miles on it, but with over 30 dyno pulls , a hard break in and since the first 1000 miles are so hard on a new engine, I took it to get an oil change yesterday. They put in Penzoil Synthetic 5 w 30.
Any idea how it compares to Mobil 1, Red Line, Amsoil or Royal Purple? I believe all the 100% synthetics meet the same standards for quality, but have you found one to be better than another?
BTW- I usually do the oil change myself and will in about another couple thousand miles, but I was tight for time with the holidays, etc.
This was done at a dealership?
I've done lots of research on this, and am convinced of the superiority of Red Line Oil, which is truly synthetic. Very expensive, but shop around on the web and bargains can be found!
I hear Red Line is the absolute best and you pay for it. I will probably do Red Line 5/30 with a K&N oil filter next time around.
Last time I checked, Pennzoil was crap. They use an lower grade sythetic base, and some of thier "synth" oils are actually blends.
Stick with Mobil 1. I've used it in every car and bike I've had since 1983 without a hiccup. I ran a Ford Escort GT (hard) to 142,000 miles on Mobil 1. I had to pull the head to retrieve a socket that fell in while I was changing the plugs (don't ask) and that sucker looked new. Sold it @ 156K miles still running like a champ.
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
We had a presentation by an Amsoil dealer last month at our club.
One thing he said startled me. -
A while back Mobil sued another maker of oil (and I think it was Pennzoil) because the other oil was labeled as synthetic but wasn't 100% synthetic. The other oil maker won the case because enough of the oil was synthetic to be so labeled.
After losing the court case Mobil 1 then started making their oil the same as the other maker since it is cheaper. So Mobil 1 is not 100% synthetic.
Amsoil is 100% synthetic.
Obviously the Amsoil dealer was trying to sell us on switching to Amsoil but he claimed that Amsoil have never been successfully sued over their claims.
Originally Posted by twolayz
dealer told me any other oil but mobil 1 voids warranty
The book also says you may ADD oil when low that does not meet that standard, but when you change oil you must use oil that meets that standard.
1 Post
St. Jude '03-'04-'05-'06
Originally Posted by SilverCoupe
Page 5-16 of the owner's manual says you may use any oil that meets GM Standard GM4718M. Oils meeting this standard may be identified as synthetic. However, not all synthetic oils will meet this GM standard.
What about Castrol Syntec? My old M5 used Castrol synthetic 10W60 (yes 10/60 no typo) and it was like $15/bottle. The BMW dealer told me it was a marketing thing and Mobil 1 or any synthetic oil was fine. First I was skeptical, then later that year a TSB came out from BMW that said that Castrol 5W30 was fine to use. Go figure.
mdcruiser:
Where can I get onformation on the Red Line synthetic? Don't want to seem trite about the cost, but nothing is to good for my baby.
Thanks in advance.
Thanks in advance.
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Which oil
Hi, I may be new to Corvettes but having two BMW's in the house, which I want to last, I have done a lot of researching about oils.
First recommendation, and this is for the whole forum, is to go the this site;
www.bobistheoilguy.com
There is evough info there that you may find yourself spending almost as much time at their site as this one.
Secondly, Mobil1, Amsoil, Redline are all pure synthetic oils. All 3 are pretty good but Mobi1 and Amsoil consistely post good UOA's (used oil analysis). If your car likes a slightly thicker oil, then the Amsoil 5W-30 seems the better choice, if your car likes it slightly thinner, then Mobil1. Amsoil is not rated, on the bottle, for the GM4718M spec but it does exceed the reqts.
Hope this helps.
Hope this helps.
Do you have any idea how much research is done in selecting an oil, why would anyone in their right mind switch to an unkown. One example if Red Line is so good and has been out so long, where the hell is it?
1 Post
Cruise-In I Veteran
Hope this helps.
Hope this helps.
Originally Posted by shafman1
I figure if the oil was good enough for the people that designed the car, than it's good enough for me.
