Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Corvette General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-06-2005, 12:22 PM   #1
GCarrHarris
CF Member
GCarrHarris's Avatar
Quote:
Originally Posted by RichieRich
That's what I did. Couple coats of red, scrape the letters, then clearcoat. Piece of cake and looks great.
Did you use high temp paint? If not, does it appear durable?
GCarrHarris is offline   Reply With Quote
Old 02-06-2005, 12:41 PM   #2
SA734
CF Senior Member
SA734's Avatar
Getting ready to do mine this week or next. You can either pay $419 plus $150+ dollars labor for the powder coated ones or buy the high-temp paint made for calipers. I researched this and found the two major brands are FoliTech and G2. Cost was $34 delivered to the door, just do a search on the web, retail is $59 and they offer several colors. I went went red for my LMB Coupe. I went with G2 because it had a higher temp rating. The only drawback is that the car (per directions) cannot be used for 3-4 days while the special paint cures. If you have a daily driver it could be a problem. I only drive mine one or two days a week so it isn't an issue. Anyone else on the Forum have additional input?
SA734 is offline   Reply With Quote
Old 02-06-2005, 12:51 PM   #3
sscamaro
CF Senior Member
St. Jude Donor '07
sscamaro's Avatar
Send a message via Yahoo to sscamaro
I am going to paint my on the C6 also. I am going to paint the caliper bracket silver and the caliper red. I painted them on my 02 SS camaro. See pics. High temp caliper paint can be gotten at most auto supply places.
http://community.webshots.com/photo/...36336350pJqZWQ
__________________
Ralph's Cars
2005 C6, Black, MZ6, Z51 Package, Polished Z06 Wheels, Corsa Extreme, Kooks LT Headers & X-Pipe,Halltech CAI, B&M Shifter, Bilstien Shocks. 388/rwhp and 380/rwtq. Ported Intake,TB & Tune by Jeremy Formato
2010 Camaro SS/RS Victory Red, MN6. Hurst Shifter, SLP Axle Back, Kooks LT Headers, Edelbrock E-Force S/C, Roto-Fab CAI. 546/rwhp 522/rwtq Tune by Jeremy Formato.(Built 9/14/09)
2002 Camaro SS (Build Date 9/10/01) Bright Rally Red, 384/rwhp and 381/rwtq (SOLD)
sscamaro is offline   Reply With Quote
Old 02-06-2005, 01:00 PM   #4
SA734
CF Senior Member
SA734's Avatar
G2 is a two-stage paint that you have to mix like epoxy and brush it on. It is made for very high-temp operations like heavy braking on a track and is also used on aircraft parts. Your Camaro calipers look good. Did you mask them off or remove them for painting?
Old 02-06-2005, 01:02 PM   #5
rwpatte
CF Senior Member
rwpatte's Avatar
Beautiful Camaro!
rwpatte is offline   Reply With Quote
Old 02-06-2005, 01:03 PM   #6
BIG Dave
CF Senior Member
BIG Dave's Avatar
I did it on my C5...
* Jack up a corner.
* Remove wheel.
* Spray the assembly with Brake Cleaner.
* Mask off what you don't want painted using masking tape and newspaper.
* For the fronts, apply a light coat of lipstick (or Chapstick) to the raised letters.
* Apply spray primer. I used the GM stuff from Fitchner Chevy.
* Apply several coats of color paint. I used GM Torch Red on my '02 however I will be using Victory Red or Black on my '05.
* Let each coat dry about 30 minutes.
* Scrap the paint off the letters. It should come right off due to the lipstick.
* Give the caliper a couple coats of GM Clearcoat.
* Move on to the next caliper.
BIG Dave is offline   Reply With Quote
Old 02-06-2005, 01:13 PM   #7
LarsAtTheBeach
CF Senior Member
St. Jude Donor '08-'09-'10
I have a Victry Red Vert inbound...
While normally I'd like red calipers (and may go red). I was considering painting mine yellow (aka ferrari). Is this a bad idea?
Thanks,
Lars
LarsAtTheBeach is offline   Reply With Quote
Old 02-06-2005, 01:21 PM   #8
coolcat
CF Senior Member
coolcat's Avatar
Quote:
Where do you buy these from, gm parts direct?
coolcat is offline   Reply With Quote
Old 02-06-2005, 01:29 PM   #9
AFVETTE
CF Senior Member
AFVETTE's Avatar
I painted the calipers (by hand using the Folia-Tec kit) and they looked great even after a few auto-X events. I used a fine metal file to clean off the paint on the COVETTE. I bought a 2003 Z a few months ago which come with the OEM powder-coated calipers.
Can you tell the difference?
1999 hand painted using Folia-Tec caliper paint kit
2003 Z06 with OEM powder-coated calipers
BTW, I paid $45 for the Folia-Tec caliper paint kit and we had enough to do two cars, so my cost was less than $30. Took about 4 hours start to finish.
Cheers
Tom
__________________
2007 Atomic Orange Z06 w/chrome spiders
AFVETTE is offline   Reply With Quote
Old 02-06-2005, 01:48 PM   #10
twolayz
CF Senior Member
Quote:
Originally Posted by King6
Anyone here planning on painting their brake calipers? Or has anyone done so already?
West Coast Corvettes seems a lot easier to me
twolayz is offline   Reply With Quote
Old 02-06-2005, 01:51 PM   #11
c6vette
CF Senior Member
c6vette's Avatar
Quote:
Originally Posted by _Nomad_
Same deal as with the C5 caliper logos, just paint the whole caliper then sand the raised letters. At least that is one way of doing it.
Thanks for repeating this-I knew there was a good way to keep paint off the lettering but could not remember.
Thanks again!!
c6vette is offline   Reply With Quote
Old 02-06-2005, 02:42 PM   #12
TRAYC6
CF Senior Member
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10
St Jude Fedex Bowl Donor '09
Support Corvetteforum!
TRAYC6's Avatar
Send a message via AIM to TRAYC6 Send a message via Yahoo to TRAYC6
I painted my own on my 98... had to do it every 6 mos.. and they never looked good enough for me... but then again, Im not a painter..decided it wasnt worth it to me... the $400 is worth getting them powder coated for me.. got them from WCC... but thats just me...
TRAYC6 is offline   Reply With Quote
Old 02-06-2005, 08:22 PM   #13
The Garage Master
CF Senior Member
The Garage Master's Avatar
The guys at MDMC are going to paint mine.
The Garage Master is offline   Reply With Quote
Old 02-06-2005, 08:39 PM   #14
TEAShea
CF Senior Member
I painted my calipers, rotor edges, hubs and the holes in the rotors with chrome aluminum paint which is high temp. I have used this paint on several cars of mine and it works well. I apply two coats. I also use it to paint the suspension components. For the exhaust pipes, which get even hotter, I use Griots's high temp aluminum paint. I have silver cars, so the silve color works well incombination.
TEAShea
from Nebraska
TEAShea is offline   Reply With Quote
Old 02-06-2005, 09:08 PM   #15
Pipedreams
CF Senior Member
St. Jude Donor '06-'07
Default duplicolor
http://duplicolor.com/products/caliper.html
used this over 6 months on my sons car (MR2 Spyder) and even through the NY winter no problems. I did not even need to remove them and just painted all visable areas staying away from the bolts. you can also do the raised letters by using a stamping block (avail in craft stores) and since the letters are raised when your press the block against them with a contrasting color, it only paints the letters
Pipedreams is offline   Reply With Quote
Old 02-07-2005, 02:34 AM   #16
SA734
CF Senior Member
SA734's Avatar
COOLCAT: You can get the painted calipers from WCC for $419 plus any applicable sales tax for the parts only. They charge about $600 installed.
Old 02-07-2005, 08:20 AM   #17
BIG Dave
CF Senior Member
BIG Dave's Avatar
Quote:
Thanks again!!
Rub some Chap Stick or lipstick on the letters before painting. The paint won't stick so it comes off much easier ...
Old 02-07-2005, 01:57 PM   #18
sscamaro
CF Senior Member
St. Jude Donor '07
sscamaro's Avatar
I removed the caliper bracket to spray paint it. I left the caliper hang and brush painted it. I used high temp caliper paint. I think they turned out great for $15.00 in paint.
__________________
Ralph's Cars
Old 02-07-2005, 04:44 PM   #19
KLO
CF Senior Member
KLO's Avatar
Send a message via Yahoo to KLO
I always use paints from www.por15.com to do my rotor hubs and calipers, I did my calipers on my black Silverado and black 96 Impala SS with the silver POR 20 which is high temp. I have decided to rework the calipers on my Machine Silver coupe, if I do it will be either a high gloss black or some type of silver close to the color of the car.....
__________________
EMAIL: koverall@cddn.com
2005 Machine Silver C6
2006 Malibu SS Black
1999 Silverado Black
1996 Impala SS Black
Zaino Distributor
WWW.TNZAINO.COM
Zaino Vendor 2010 C5/C6 Bash
KLO is offline   Reply With Quote
Old 02-13-2005, 09:21 PM   #20
docrings1
CF Senior Member
C6 FAQ Master
docrings1's Avatar
Default Rear DIY caliper paint procedure (non-removal)
Just did my rear caliper using the Plasikote 900degree caliper paint (Wal-Mart $3.79). I have used it on an SLK230 and a Lexus GS400 three years ago, and their calipers still look good without discoloration or chips, so I stayed with it for the C6.
Steps:
Removed the wheel,
cleaned with brake cleaner,
masked with tape/newpaper,
five thin coats of spray,
hand touch-ups with a foam brush/q-tips,
minor overspray cleanup on rotor with lacquer thinner and clean q-tips,
and letting everything dry about 45 minutes before removing the paper,
then remounted the wheel.
Overall time, about 1.5 hours.
I might end up doing both fronts at the same time, and have the car up on jack stands for that, as it would be more time efficient than one caliper at a time.
(Notice brake cooling duct in first photo... flush intake is on bottom of car)
I will post more pics for the fronts probably next weekend.
__________________
Keeper of the C6 FAQ
F-14A, B & D; F/A-18D; T-34C; C-130 "Fat Albert"; TH-57A & C; C-2; C-9; CH-53E; H-3; H-46
docrings1 is offline   Reply With Quote
Reload this Page Plan to Paint Brake Calipers?
Tags
brake, break, c5, caliper, calipers, car, chrome, corveette, corvette, diy, lexus, paint, painted, painting, pics
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Some Advice on Painting the Calipers jchazr C6 Corvette General Discussion 12 08-05-2005 05:37 PM
Anyone Have a Good Caliper Painting Writeup? Dave1998 C5 General 22 06-30-2005 06:10 PM
Painting Brake Calipers c6vetteowner C6 Corvette General Discussion 10 04-30-2005 11:05 PM
Sportbrake Crossdrilled/slotted & Rotor Removal Question? Vettesic C5 General 19 11-20-2004 12:38 PM
My Brake Job CaliforniaVette C4 General Discussion 14 03-26-2004 05:30 PM
Painting Brake Calipers LT1TKO C4 General Discussion 13 01-29-2004 10:10 AM
I need a little help developing a plan of attack phoenix C3 Tech/Performance 13 10-23-2001 10:26 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
