Someone told me C6 has E gas
C2 of the Year Finalist - Unmodified 2020
something to do with the gas petal,I know the c5 has no mechicial linkage to the engine,does anyone know what he is talking about?Said the porsche has it and he does not like it? thanks in advance!
Received 1,974 Likes
Beginning with the new C5 in 1997 all Corvettes have an electronically controlled throttle. There is no direct mechanical connection between the throttle pedal and throttle valve. The pedal talks to the Powertrain Control Module and the PCM commands the throttle stepper motor on the throttle body.
A number of cars, particularly in the higher price ranges, have similar systems.
Parameters such as throttle tip-in rate are controlled by software, but I don't know of any way for owners to modify the OE programing.
Duke
Duke
Yes, (beginning with the C5 LS1) there is no mechancial linkage from your right foot to the throttle body. This enables lots of things to be controlled more seamlessly, reduces weight and will be as common as ABS brakes some day, if not now. For example, your Cruise Control can be electronically controled by the computer, rather than a control modual with a second cable attached to the TB. It helps speed and control messages to the ABS and the engine for the active handling program. All of these messages (right foot, active handling, and traction control) travel through a single control to the TB.
This my laymen's understanding - anyone pitch in and correct if I mistated anything.
BTW, if your friend does not like this feature, maybe he is frequently trying to do things that the computer programming "thinks" are not smart, so it overrides him. I have read that some active handling systems can not be completely turned off (I don't know about Porsche's), which means that at the limits of handling - like on a track or autocrossing - the computer might interfear with the driver's control. The Vette has always had an override capability that allows the driver to completely disable the active handling program and be as stupid as his insurance will cover - even more stupider.
1 Post
St. Jude '03-'04-'05-'06
Originally Posted by LongTimer
...... The Vette has always had an override capability that allows the driver to completely disable the active handling program and be as stupid as his insurance will cover - even more stupider.
Guest
Posts: n/a
Originally Posted by Another Yellow
So well put.
I really enjoy the posts from the folks who think they are real hotshoes, and don't need active handling & electronic assistance to help them in emergency situations - because they're such good drivers. There was a certain moderator on here a couple of years ago who found out the hard way that
(active handling = off) + (large_tree) = (badly_bent_z06)
Duke
Sorry you are not such a good driver.
Back to the TOPIC. As you can see, I DESPISE the active handling. I'm not opposed to the concept, but I don't see the implementation is quite there yet. It is abrupt and harsh. When they can implement it in a way where I can't tell it is happening then I will be more accepting of it.
However, with those qualifications, and seeing that I am perhaps one of the most ardent opposers of Active Handling, let me say that I have NO PROBLEM with the Corvette gas pedal implementation.
You can't tell it is "fly by wire." It feels like a gas pedal, and best of all - there is no annoying surge and pulsing when you have cruise control on while driving on the interstate.
You won't notice it is there and I don't know what your friend is doing with his Porsche, or how they implement it - but the Corvette gas pedal is a non-issue.
