LS7 Confirmed & to be hand built!
quote from GM release today...
I also heard it first hand, as i was actually AT the Performance Build Center today
The first hand-built engine variant to come from the Performance Build Center will be the LS7 OHV V-8 that is the heart of the Z06 performance package earmarked for the 2006 Corvette; specifications and details for the LS7 will be provided at the 2005 North American International Auto Show.
Part by hand and part robots?
Some believe that because the engine is labeled LS7, that means that the displacement will be the 6.4L (some say 7.0) as per the RPO of a year or so ago (You may have been the one who found that!).
Do you believe this announcement confirms the displacement size and if so, what size?
Here is a link to the release. Says they are hand building special engines for multiple cars/trucks. Total capacity is 15,000 per year in a "flexable mix" so that says something about possible Z06 volume.
One person builds it from start to finish. I would guess that you get a card or signature of something from the builder.
http://media.gm.com/servlet/GatewayS...=74&docid=6373
Originally Posted by ivan111
How is the LS2 built?
CF Co-Founder
Originally Posted by JLinNY
I don't know about the LS2, but the LS1 was partially built by people. Vette magazine has an article about it several issues ago.
I would have liked to see that article.....
I would imagine that both the LS2 and LS6 are built partially by people like the LS1.....
1 Post
Originally Posted by scorp508
And the price.
It was a great article in Corvette Magazine. I thought it was really interesting how they did the rod caps by scoring and breaking them off the rod. I read the article pretty fast and I guess I should reread it about that part at least. It stands to reason that it should be the best way of fitting and balancing the endcap to the rod. I guess before this they were all cast or forged separately then machined to fit. Has this ever been done before by any other manufacturer?
Received 1,974 Likes
"Hand built" can mean almost anything. In this case it's probably just marketing BS to catch some attention. Machine built items are generally more consistent and therefore higher overall qualilty. Corvette paint quality took a quantum leap when robots replaced human painters. Modern robots are vastly better than humans at repetitive tasks. They don't get tired or have brain fade on Friday afternoons or Monday morning hangovers.
Chances are that LS7 components will be machined on the normal transfer lines or CNC tools if volume is really low.
The assembly operation will probably not be as automated as the high volume engines. Thus they are tagged as "hand built", but I would prefer as much automation as possible. Once automation is dialed in you get increadibly consistent dimensional tolerance and assembly consistency/quality.
Duke
Duke
Duke
Originally Posted by Troy Roberts
Looks like GM is imitating the success of AMG>>
which is a good thing..Mercedes AMG has clearly demostrated that 'one person builds one engine' and having a focus on performance works...I always smile a bit when you look at a AMG engine and see a signature plate of the fellow who built the engine...on my SLK AMG 32 the fellow actually etched his signature on the block...maybe his care produce a slightly better engine since it has been dynoed at 11 hp over advertised crank hp of 349 hp
CF Co-Founder
drat.. well, i was actually there so there :p:
That's why I was able to beat you to posting it! You need to take a wireless laptop along next time.
