*New* C6 Front License Plate Mount!
Old 06-15-2004, 07:03 PM
PhantomPredator
PhantomPredator's Avatar
Default *New* C6 Front License Plate Mount!
C6LP-SE
Click here for 800x800
The C6LP-SE is a front license plate mount for the Corvette C6. The Corvette community was extremely disappointed after the revealing of GM's solution, and change seemed unlikely due to engineering concerns expressed by GM. C6LP-SE is designed to address most community concerns while respecting engineering concerns.
The C6LP-SE mounts to the inside of the mouth, making holes less noticeable upon removal. The C6LP-SE is lowered slightly to flow with the car and hide the underside mount, while not obstructing the mouth. The height of the C6LP-SE is reduced to minimize visual effect and groves are added to hold the plate. The 'flush with the body' idea is scrapped to remove the brick-like qualities. A small amount of padding is added behind the mount to prevent scraping and scratching on the nose. The C6LP-SE is a two-piece system that allows the larger portion to be detached easily while the remaining piece is not obvious.
More Views...
C6LP-SE on C6
http://www.gryphonauto.com/features/...s-temp/010.jpg
http://www.gryphonauto.com/features/...s-temp/011.jpg
http://www.gryphonauto.com/features/...s-temp/013.jpg
http://www.gryphonauto.com/features/...s-temp/016.jpg
C6LP-SE alone
http://www.gryphonauto.com/features/...s-temp/001.jpg
http://www.gryphonauto.com/features/...s-temp/003.jpg
http://www.gryphonauto.com/features/...s-temp/004.jpg
C6LP-SE Cut-away
http://www.gryphonauto.com/features/...s-temp/009.jpg
C6LP-SE parts:
http://www.gryphonauto.com/features/...s-temp/007.jpg
http://www.gryphonauto.com/features/...s-temp/008.jpg
http://www.gryphonauto.com/features/...s-temp/015.jpg
C6LP-SE Grove:
http://www.gryphonauto.com/features/...s-temp/006.jpg
BLUE is the padding
RED the plate itself.
[Modified by PhantomPredator, 12:05 AM 6/16/2004]
Old 06-15-2004, 07:10 PM
Tom73
Tom73's Avatar
Default Re: *New* C6 Front License Plate Mount! (PhantomPredator)
Still doesn't work for me. Need to get the plate off of the nose. Maybe move it to an offset position at the end of the grill.
tom...
Old 06-15-2004, 07:17 PM
charliesc5
charliesc5's Avatar
not pretty
Old 06-15-2004, 07:37 PM
murnutz
murnutz's Avatar
Default Re: *New* C6 Front License Plate Mount! (charliesc5)
not pretty
At least Phantom has made an concerted effort to come up with something that is not as obtrusive as GM's design. That is something more than 99% of us on here can say! I applaud your efforts Phantom. I don't think that it is that bad looking. It would be interesting to see a prototype of this on a C6 when they hit the streets.
Old 06-15-2004, 07:42 PM
Mr Mojo
Elite Torch Red Member
Support Corvetteforum!
Mr Mojo's Avatar
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: *New* C6 Front License Plate Mount! (murnutz)
Still not pretty but better than what we saw earlier.
Old 06-15-2004, 08:50 PM
Another Yellow
Another Yellow's Avatar
St. Jude '03-'04-'05-'06
Something to consider if I decide to use a front plate. Thanks for the effort.
Old 06-15-2004, 09:25 PM
Hurricane
Moderator
Hurricane's Avatar
Cruise-In I Veteran
Default Re: *New* C6 Front License Plate Mount! (Another Yellow)
I think the original (stock) one looks much, much better.
Old 06-15-2004, 09:36 PM
Curtis A. Franz
Curtis A. Franz's Avatar
Still a near miss. Put the thing over to one side.
[Modified by Curtis A. Franz, 6:36 PM 6/15/2004]
Old 06-15-2004, 10:07 PM
BuckyThreadkiller
Successful Plumber
BuckyThreadkiller's Avatar
Location: Top of the hill, 3rd mailbox on the right. Texas
CF NCM Ambassador
CI 6-7-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10
NCM Member '09
Default Re: *New* C6 Front License Plate Mount! (Curtis A. Franz)
To heck with the license plate bracket.
Please tell me that isn't Dave Hill in a bucket hat and bright red pants.
Old 06-15-2004, 10:12 PM
Mr Mojo
Mr Mojo's Avatar
Default Re: *New* C6 Front License Plate Mount! (BuckyThreadkiller)
Old 06-15-2004, 10:46 PM
Dominic Sorresso
Dominic Sorresso's Avatar
Horrid!
Old 06-15-2004, 11:13 PM
barkingowl
barkingowl's Avatar
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: *New* C6 Front License Plate Mount! (Dominic Sorresso)
The front plate frame should have been inset into the nose so it could be covered with a plate if you live in a state where you don't need to run a front plate.
Old 06-15-2004, 11:25 PM
Hurricane
Moderator
Hurricane's Avatar
Cruise-In I Veteran
I was thinking the same thing! Quick - where are those guys from BRAVO?
Old 06-15-2004, 11:29 PM
need-for-speed
need-for-speed's Avatar
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
Nice work. This is just about the only option there is.
Old 06-16-2004, 01:22 AM
Tremendous
Tremendous's Avatar
St. Jude Donor '05
Default Re: *New* C6 Front License Plate Mount! (need-for-speed)
To re-state the obvious, it will always look better without a plate. It's a matter of taste whether the plate looks better centered or offset to the driver's side, but I think this design is a definite improvement, and the best we can hope for without reducing air intake.
I wouldn't use the GM FLB but I would use this one. This is what I expected GM to come out with in the first place.
GM's decision to conform the FLB to the body is just ugly.
[Modified by Tremendous, 6:29 AM 6/16/2004]
Old 06-16-2004, 01:52 AM
PhantomPredator
Is it crappy? You can bet your Corvette that this is a crappy mount. However, what it all comes down to is that mine is significantly less crappy than the GM option.
I wish I could do better, but my options are rather limited. The license plate really cannot be moved from its current location, except for to the left or the right (which my mount can handle). Making the holes in a less obvious spot makes the design slightly awkward, but I hid most of that fairly efficiently. The only other real options (other than a time machine) are to replace the entire front fascia with something more stylistic like this or this.
I mean, given the option of the brick (GM's LP mount) or my LP mount, which would you chose? (Hmmm...maybe I should have created a poll.)
[Modified by PhantomPredator, 7:10 AM 6/16/2004]
Old 06-16-2004, 03:40 AM
PhantomPredator
I did a quick test moving the mount, and it appears that you can move it left and right with ease and it won't cause problems. Took a quick screen-shot...I'm not sure exactly where people want it (except the center)...so I'll need recommendations for the location before I create more pictures.
http://www.gryphonauto.com/features/...s-temp/018.jpg
[Modified by PhantomPredator, 8:41 AM 6/16/2004]
To *New* C6 Front License Plate Mount!
Old 06-16-2004, 07:38 AM
Mr Mojo
Mr Mojo's Avatar
It's a Corvette not a Semi Truck, putting it to the side would make it worse. The center is the only logical location.
Old 06-16-2004, 08:04 AM
Tom73
Tom73's Avatar
Default Re: *New* C6 Front License Plate Mount! (Mr Mojo)
Move it to the side and then down into the grill area next to the park/running lights.
Old 06-16-2004, 10:38 AM
PhantomPredator
Default Re: *New* C6 Front License Plate Mount! (Tom73)
Moving it to the side and in front of the intake would probably be a disaster, both aerodynamics and engine bay ventilation.
Moving the plate to any place other than somewhere in the center is a much greater eyesore than making GM's mount 2 inches thicker. You'd have options with my mount, but I'd recommend the center.
Quick Reply: *New* C6 Front License Plate Mount!
