C6 Z06 Pic
Guest
Posts: n/a
C6 Z06 Pic
I found this pic of a C6 Z06. Looks nice, just not my color. Try @ the bottom of this site: http://www.corvettesbyrickdaniel.com/C6INFO.html
☠☣☢ Semper Ebrius ☢☣☠
Re: C6 Z06 Pic (Z06CTSV)
That pic isn't an accurate representation partly because the C6 Z06 will have the fastback rear glass, just like the Coupe.
Re: C6 Z06 Pic (Scissors)
That's the first I've actually seen anyone say that (I may have missed it). Do you know that for sure?
Thanks! :cheers:
Re: C6 Z06 Pic (yellow01)
Thanks! :cheers:
Thanks! :cheers:
Location: Recovering from a tragic boating accident in Jacksonville Fl
CI 5-6-7-8-9-10 Vet
Does that mean that the C6 Z06 will have a Targa top? :D :eek:
Guest
Posts: n/a
Thanks! :cheers:
Shouldn't be, since it's been said for a while that the C6 hardtop will have the Coupe's roofline. The C5 hardtop was a styling SNAFU and the only way they were able to save it was to give it a better engine. This time they won't make the same mistake. This time the higher-performance 'Vette will actually be able to go faster than the base level one.
Thanks! :cheers:
Cruise-In IV Veteran
Re: C6 Z06 Pic (jrg007)
Thanks! :cheers:
I strongly disagree with you Scissors!!!!!
Thanks! :cheers:
Thanks! :cheers:
Thanks! :cheers:
Re: C6 Z06 Pic (PeteyPete)
Maybe i'm just in the minority, but I actually chose to buy a FRC b/c I prefered the hardtop styling over the coupe. I find the rear styling to be more aggressive and chose it over the coupe....so i guess i wouldn't consider it a "SNAFU".
Sorry, but it's logical the Z06 is not the same as a Coupe. Glass weighs quite a bit, and a FRC body is more rigid and more balanced.
Newsflash #2, the FRC is no more rigid/balanced than the convertible is.
Re: C6 Z06 Pic (scorp508)
PeteyPete: I agree with you wholeheartedly. I've always preferred the FRC look to the coupe look. But, looks are entirely subjective.
scorp508: If you can't feel the difference between an FRC and a convertable, you need to either sample a few more or have your a** recalibrated.
Cruise-In V Veteran
I think it will look like a Coupe but have a fixed roof.
The Coupe has less drag and I'd think that would be of help for the Z06
Re: C6 Z06 Pic (MJM)
[Modified by CorvetteSS, 4:28 PM 1/2/2004]
