Where whould you like to see the gas cap on the C6?
Re: Where whould you like to see the gas cap on the C6? (vettemaan)
The spy shots of test cars show the filler opening relocated to a position higher on the left rear quarter and further back than on the C5. Since that's not the sort of thing one would disguise, it's likely to be the real location, and that small portion of the body may well be correct. Obviously, the last 24 inches or so are heavily-disguised.
Where the cup holder is....
Hey-Just kidding. I voted same place as C5. And if I find that C6 turns out to be a keeper, I'll put on a nice metal flip open.
Re: Where whould you like to see the gas cap on the C6? (SHOWTIME!)
What was wrong with the way the C4 had it? You could pull in the gas station on any side.
I'm guessing the exact same location as the XLR.
Re: Where whould you like to see the gas cap on the C6? (Shylor)
Re: Where whould you like to see the gas cap on the C6? (Jinx)
Stretching the hose to the middle of the car is a pain.
Re: Where whould you like to see the gas cap on the C6? (GDP)
I like the C3,C4 spot in the center rear.
ATTN GM: The C5 location forces the driver to open the (large) door into the fuel station pump. Please relocate the fuel door. :yesnod:
On the curve of the fender, like speculated on the C6 pics.
☠☣☢ Semper Ebrius ☢☣☠
The circle on top of the fender and cut into the hatch is not the fuel door. The fuel door will be in exactly the same location as it is on the C5 and XLR.
Re: Where whould you like to see the gas cap on the C6? (Scissors)
Re: Where whould you like to see the gas cap on the C6? (Sun King)
You'd have to open your door into the fuel pump no matter where the gas cap is. Just don't pull in so close to the pump next time.
And, in my 79 and 95 I pull up on the Left side for the same reason.
